Old 09-20-2017, 10:16 AM   #1
1969 25' Tradewind
Somewhere , Minnesota
Parbond, Gutterseal, Vulkem?
I've heard a lot about these three sealants(Par bond Gutter Seal and Vulkem) but don't haven't heard a good consensus on when to use each one. Could anyone give a general idea of what types of applications each is best used for?
Instagram - @GoToasterGo
GoToasterGo.com...coming soon!
Full Monte and Renovation Thread found at the link below:
GoToasterGo '69 Tradewind Renovation
GoToasterGo is offline   Reply With Quote
Old 09-20-2017, 10:23 AM   #2
dznf0g's Avatar
Oswego , Illinois
I don't use gutterseal.
Parbond = small seams where waterproofing is needed. ie, top of center belt molding; around battery doors, tail light housings, marker housings, etc. I'd say less than 1/8" gap.
Vulkem (Sikaflex) = Larger gaps and roof item sealing. (I use the UV formulas) ie, awning rails, roof rails, lower belt molding tops, window eyebrows etc.
When you have specific areas you are sealing, and are unsure, just ask.
-Rich-
Old 09-20-2017, 10:58 AM   #3
1969 25' Tradewind
Awesome! Thanks for the info.
Old 09-20-2017, 11:44 AM   #4
2011 22' Sport
Portland , Oregon
Out of the massive sealant thread here is the summary that I collected:
For wheel wells/underbody:
Vulkem 116
Trempro 635 Grey
Sikaflex 221 Black (use Eternabond spray cleaner to prepare surface)
Adseal Premium Quality Sealant Grey
Roof:
Sikaflex 221 White (for roof seams, seals and bonds. Use Eternabond spray cleaner to prepare surface)
Sikaflex 715 (around fans, vents, skylights ... self-levelling)
Adseal Premium Quality Sealant White
Dicor self-levelling sealant
EternaBond® AlumiBond (alum. backed sealing tape, 2", 3", 4", and 6" wide)
Lexel™ Clear
Windows/Trim/Rubrail/Exterior Lights:
Sikaflex 221 Grey (seals and bonds. Use Eternabond spray cleaner to prepare surface)
Parbond Grey or Clear (small hand tubes, prep and clean-up use cosmoline remover)
Trempro 635 Grey
Loctite® PL® S40 Polyurethane Window Door and Siding Sealant
Lexel™ Clear
Small seams (between aluminum panels):
Acryl-R (available in cans from Airstream store. Use applicator or disposable syringes to apply)
Aluminum Pigmented Gutterseal
Rivet sealer:
Captain Tolley's Creeping Crack Cure
Parbond Gray or Clear (small hand tubes), also good for small gaps (<1/8”) such as top of belt line rub rail, door/window frames, etc
SilverHouseDreams is offline   Reply With Quote
Old 09-20-2017, 11:44 AM   #5
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
I use Vulkem for just all exterior purposes on the Airstream, including smaller cracks where others use Parbond. (My own observations -- completely unsystematic, I might point out -- suggest that Vulkem withstands the effects of outdoor sunlight better than Parbond.) When using Vulkem, run tape along both sides of the small crack, apply a small bead, smooth with finger, remove tape.
Lynn
ACI Big Red Number 21043
eubank is online now   Reply With Quote
Old 09-20-2017, 01:32 PM   #6
Opinionated newb...
wave man's Avatar
2018 25' Flying Cloud
League City , TX
You make it sound so easy, apparently I need waaay more practice on that technique
if my last attempt is any indication... bathroom caulk ...fail 😒
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Old 09-20-2017, 06:29 PM   #7
1969 25' Tradewind
Xipper that's an amazing summary. Thank you.
Old 09-20-2017, 08:39 PM   #8
2011 22' Sport
Portland , Oregon
The credit goes to everyone that contributes to that 30 page sealant thread. I just spent the time reading and reading and collecting and editing to try and get “final consensus”.
Caulking and Sealants (silicone, parbond, vulkem & more) Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 266 07-01-2017 12:41 PM
Alcoa Gutterseal ups and downs 86Scotty Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-13-2008 09:17 PM
Where to buy Vulkem and Parbond in B.C.? fancy pants Leaks - Weatherstrips, Gaskets, Caulks & Sealants 13 05-17-2007 01:25 PM
Vulkem vs. ParBond 68Glbtrotter Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 10-04-2006 11:17 PM
Sikaflex, Vulkem, and Parbond Questions JohnG Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 07-27-2004 09:06 PM
