Old 01-17-2020, 02:43 PM   #1
2008 532 International
New Braunfels , Texas
Outside Over Entry Door Light.
2008 Flying Cloud 25 footer. Light bulb has burned out above the entry door. The cover has 2 screws holding the cover on but it appears to have a rubber gasket securing it to the body of the trailer. Is there a trick to this process? Should I simply pry the cover off and then apply another gasket of some sort? I don't want it looking like poop.
Also, are there LED bulbs that can be used instead of the OEM bulb?
Thanks in advance.
Nancy and Andy
Andy and Nancy
25' 2008 International Ocean Breeze CCD
2002 Lariat F-250 7.3
Ext Cab Longbed
Harley occasionally in the bed.
StreamGlider is offline   Reply With Quote
Old 01-17-2020, 02:54 PM   #2
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
When I replaced the incandescent light bulb on our 2007 Bambi with LED, I was able to just remove the clear lens cover, I did not have to mess with the metal casing.
Steamy1 is offline   Reply With Quote
Old 01-17-2020, 03:01 PM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Do Not take the metal off the aluminum skin! It is caulked In place. The lens cover on the bottom is removable and the bulb should be able to be replaced with an LED in there? When I get home I’ll post a pic of the process
Old 01-17-2020, 06:55 PM   #4
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Following. Jim
Jim Flower is online now   Reply With Quote
Old 01-18-2020, 10:19 AM   #5
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Yes, replace with LED lighting - in fack spend a little money now and replace all you light bulb interior and exterior LED's works out to about 1/10th the power draw on the batteries.
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 01-18-2020, 11:31 AM   #6
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I had to remove the two screws below the lens cover to get more clearance. I then pryed the lens cover off. You remove the burned out bulb and replace it with either an LED board that has two wires to bayonet base or go with an LED bulb with that type of base. I went with the second option.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-18-2020, 01:22 PM   #7
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
X2
Originally Posted by Jim Flower View Post
Following. Jim
X2. I’ve got to change mine, too. Either one of my two bulbs burned out or the one bulb won’t light on one side. (Thx Dr. Suess!)
GammaDog is offline   Reply With Quote
Old 01-18-2020, 01:32 PM   #8
The interior is 95% LED already. What a difference when we changed those out.
Not sure where or what to do now with the over door bulb. Where do I find an LED that will work on the wiring that I already have? I only need one LED, but how can I be sure what will be compatible with the "socket" that it goes in to?
Man, I can hear the "How many XXX does it take to change a lightbulb" jokes. lol
Andy and Nancy
Ext Cab Longbed
Old 01-18-2020, 03:01 PM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Dan is the man, for LED's👍
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
“Growing Old…being able to think about things you can no longer remember.”
RLC
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 01-18-2020, 04:41 PM   #10
1976 31' Sovereign
Oswego , Illinois
The bulb is probably 12 volt bayonet style. A 12 volt led same config. use w/nothing else to do just twist in, no spec. any thing.
featherbedder is online now   Reply With Quote
Old 01-18-2020, 07:12 PM   #11
2007 22' International CCD
I replaced mine with a square LED array with a jumper wire to the bayonet socket. Lots brighter with no heat. Got it from LED4RV.
Old 01-18-2020, 07:26 PM   #12
waninae39's Avatar
2017 22' Sport
NCR , Ontario
keep the alum cover on. DO NOT REMOVE!
it is easy to get an LED assembly to fit inside. AS sells one or just get one off ebay/amazon
Name:	ext door light inside.jpg
ID:	359389   Click image for larger version
Name:	ext door light front.jpg
Name:	ext door light case.jpg
waninae39 is online now   Reply With Quote
Old 01-19-2020, 10:11 AM   #13
100 Mile House , British Columbia
Hey there. Would mind giving the name/part number/source for that LED unit? I’d like to get one for my ‘74. Thanks!
Old Farm Guy is offline   Reply With Quote
Old 01-19-2020, 11:03 AM   #14
Here.... Call 👍
Molly Ivins
RLC
Sweet Streams....🌥
Old 01-26-2020, 08:27 PM   #15
2010 25' FB International
Livermore , California
Our 2010 International used a T10 bulb which I replaced with this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
...however I found that bulb frequently rattled loose so I replaced it with a bayonet (1156) socket and this bulb https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
MotoMannequin is offline   Reply With Quote
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 07:07 PM
over the door outside light moparjohn 1970-79 Tradewind 4 08-13-2010 10:08 PM
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 06:53 PM
Light or light cover over the door.. help please! harestream Lights - Interior & Exterior 19 08-29-2008 10:51 AM
Entry door bolt lock with an outside key willyd Doors & Locks 4 06-22-2008 02:07 PM
