03-16-2020, 01:54 PM
1992 29' Excella
Virginia Beach
, Virginia
Oops, screwed into our black tank.
While screwing down our new floors, we screwed into our black tank about 1/4". Not a through and through but want to do a plastic weld to prevent it getting any worse but need to know what type of plastic the tank is made of. Anyone out there know? We have a 1992 Excella. Thanks!
03-16-2020, 02:41 PM
1973 21' Globetrotter
Houston
Is the plastic black, or white? If black, it is probably ABS. If White, probably HDPE.
good luck!
03-16-2020, 02:59 PM
My tank is black HDPE. Try using a soldering iron or heat gun. If it's HDPE you can just smoosh the hole closed.
If ABS you can just solvent glue a patch on.
03-16-2020, 03:10 PM
2019 30' Classic
New Milford
, Pennsylvania
3M5200. Purchase at Lowes. Expensive but water won't bother it and won't come off. boatbuilders use it all the time
03-16-2020, 04:43 PM
CLOUDSPLITTER "Tahawus"
Zanadude Nebula
, Milky Way
X2
Great addition to the AS tool kit. Many uses.
I just used it this morning to insulate a wiring repair on my e-bike battery. 👍
“It’s not the system thats the problem, think Circus, it’s not the car, it’s that the car is full of Clowns.”
John Turley
Tahawus
03-17-2020, 09:24 AM
1992 29' Excella
Virginia Beach
, Virginia
Thanks for all the tips. We found someone who does plastic welding who is coming out today to fill and weld the hole.
03-17-2020, 10:24 AM
2018 22' Sport
Ludlow Falls
, Ohio
That's the best way. Not much sticks to HDPE.
03-17-2020, 11:38 AM
1992 29' Excella
Virginia Beach
, Virginia
So you are seeing double posts on this topic. My husband posted as well. One hand not telling the other what we've done and here we are. Thanks again everyone!
03-20-2020, 07:06 PM
2008 22' Sport
Spicewood (W of Austin)
Clean the area with electronic cleaner aerosol and let it dry...then patch with JB Weld. Permanent fix.
03-20-2020, 10:00 PM
Paradise
Stainless #10 screw with a dab of sikaflex 221. Good for many years
