Old 05-06-2021, 04:06 PM   #21
Houston , Texas
Originally Posted by GCinSC2 View Post
Rage51,
I tried to find a manual on the 7355, no luck. It's a convertor and distribution center.
Are the 30A fuses supplying power from the convertor to the batteries?
Couple ideas, pull the batteries, what is the age of the batteries, check water level and put them on an ordinary battery charger. Overnight or so. See if you can get them tested or check the voltage a while after charging. A hydrometer can be a good tool to check battery health too. I'm also wondering if there is a way to disconnect the convertor from AC power and just hook up a good 30A or so battery charger for a test run.
I wonder if your convertor and/or batteries are done.
Electrical armchair diagnostics has it's limits, proceed at your discretion and comfort level.
Gary
I think the 30amp fuses are converting shore power to all devices that run off the battery, including the battery itself. I think something in the converter is failing, and vibrations during travel either make it work or not.
Since the refrigerator no longer switches from gas to electric automatically, and since I canít seem to find a ďsmoking gunĒ, I have decided to take it to an RV repair place Iíve used before. We have some long trips planned far from home and this situation is too unstable. Iíll share the results when I get them for future reference.
Rob
Rage51 is offline   Reply With Quote
Old 05-12-2021, 06:17 PM   #22
2016 25' Flying Cloud
Cedar Park , Texas
No battery power
I had the same problem for a year. I removed the post connections scrubbed them with a wire brush added some dialectic grease. Never have had a issue again.
brendakerry is offline   Reply With Quote
Old 05-14-2021, 04:43 PM   #23
Houston , Texas
Thanks for the tip. The trailer is in the shop, so if it’s a battery connection problem, I will be summarily embarrassed...
Battery Good No DC Power with shore power off. F Ross Batteries, Univolts, Converters & Inverters 18 10-25-2018 10:06 AM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
