Old 12-18-2017, 10:35 PM   #1
1973 31' Sovereign
Richmond , Virginia
New owner '73 Sovereign, here’s to hoping
I’ll keep it short for now but my wife and I live in Richmond Va and just took on a 31’ 1973 Sovereign. It was a total gut job and we’re down to the subfloor which will need to be replaced. We have much of the same story as many of y’all, she’ll need double pane windows cleaned out, new gaskets, new axels, new vents, the whole nine.
The longer I spend reading through threads the more overwhelmed and underprepared I feel. We renovated a class B camper last year and so I felt like we were ready for our next project, this time with hopes of full time living for us and the dog. I’m relatively handy and have done a bit of carpentry but it turns out Airstreams aren’t made of wood. Words of encouragement and bits of advice from wiser folks than me would be appreciated.
Where we are now I’m trying to decide if I should replace vents and window gaskets before the floor? Should I seal the interior seams just as a means of caution since I don’t know yet what leaks and what doesn’t? I’m terrified to look under the floor at the frame so should I just bite the bullet and pull the floor out first?
Looking forward to getting to know you all, I love how friendly and eager to help everyone here is.
David
ID:	301138   Click image for larger version
Arlene2 is offline   Reply With Quote
Old 12-19-2017, 04:38 AM   #2
Mantua , Ohio
I would check the frame for rearend sag and rust before going on with the interior. Drop the belly pan for a look.
Old 12-19-2017, 05:00 AM   #3
Chatthayer's Avatar
1972 25' Tradewind
Chattanooga , Tennessee
Images: 21
A day and a project at a time. Easy to get overwhelmed. You have done a lot already. A power washer or strong hose stream while you watch inside can help identify your leak issues.
Best wishes and Merry Christmas.
Steve
Steve and Tobie Thayer
chatthayer@gmail.com
Chatthayer is offline   Reply With Quote
Old 12-19-2017, 08:52 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
If she's sitting outside, definitely seal leaks and make her weather proof before tackling the floor (windows, door, roof vents, seams, storage areas). I doesn't do any good to the floor to have a new one get wet. THEN, tackle the floor. We had extensive home renovation experience, but not trailer renovations when we started our '72. We also did a total gut job, and it was WORTH IT!
We did a lot of forums reading before and during our renovation, asked questions on the forums, and dug out our own answers many times.
There's a "renovation threads " thread here on the forums with a very long list of peoples adventures. Ours is "Little Girl Refurb" in the '70's section.
Good luck and keep posting!
Kay
Old 12-19-2017, 12:18 PM   #5
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Hopefully you saved your interior skins? At least to use as patterns?
Your existing sub-floor will tell you whether or not you have leaks. Any nastiness that's not where the bathroom was is under a leak. Grab your scratch awl and poke the floor all over to find any soft spots. Tearing out the windows and vents is a big job, and you could wind up with more leaks than you started with!
Be sure that you're roadworthy first- check your frame sag, brakes and axles. Actually, you should get some tunes in there, and a couple of patio chairs. Laying out the new design, dreaming of trips, figuring out cool hacks, that's half the fun! Be forewarned- I've found these "design meetings" to be thirsty affairs!
SuzyHomemakr is offline   Reply With Quote
Old 12-19-2017, 08:15 PM   #6
1973 31' Sovereign
Richmond , Virginia
Thanks so much!
Yeah the floor around the door and in the rear from the notorious bumper compartment is totally toast and you can see the rearmost cross member attests needs some serious attention.
We did save the skins and are planning to reuse most of them, some are cut up a little too much so we’ll probably replace some sections.
There’s a small amount of rust on some of the roof seams that I’ll clean and seal. I’m thinking now I’ll start by Installing the new vents, AC, racks for solar and new window gaskets. My thought is that while it’s torn down this far address anything that is or could become an issue.
I’ll take a look at your thread and keep trying to navigate the forums.
Thanks so much!
Old 12-19-2017, 09:00 PM   #7
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
Check out an of Beans, which is the rehab of a 73 Sovereign, although they claim it is a '72. It is a 73, and I know, because it was ours before we gave it to them.
Susan
Best of Luck!
duncans is offline   Reply With Quote
Old 12-19-2017, 10:25 PM   #8
2003 25' Safari
salem , West Virginia
Welcome and congrats, you will get angry and discouraged but it will be offset by the joy and fun to come.
My wife and I live full time In our 31’ 81 excella and are currently parked just outside of Richmond. This is our 2nd airstream, it was mostly renovated when we got it but still have done and plan to do lots more work.
Check for and fix leaks first and continuously monitor, try to seal outside anywhere you know there are leaky rivets, etc. and seal all the seams/rivets inside while you can just for added protection in the long run it will save you lots of time and effort to do it now.
Be sure to use appropriate sealants. There are numerous threads on nothing but that. You’ll need at least a couple different types depending on the application.
Also consider buying this book it’s quite useful, you can get all of the info on here for free but this is a pretty handy resource.
“Airstream Life's (Nearly) Complete Guide To Airstream Maintenance”
Jeremiwvu is offline   Reply With Quote
Old 12-19-2017, 11:57 PM   #9
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
I would get busy on the frame you might need to remove parts of the floor to do a good job on the frame. Then start chasing leaks, And start the new floor at the same time, you won't get all the leaks stopped first try, and shifting the shell around during floor replacement might cause new leaks.
Good luck!
bibbs is offline   Reply With Quote
Old 12-19-2017, 11:59 PM   #10
Jhess's Avatar
2017 22' Sport
Johns Creek , Georgia
I cannot imagine taking on that much work myself. I was overwhelmed by just installling a cell booster to our Airstream. I’m happy with the result but don’t think I’d do it myself again. Stress! Hats off to you for having the gumption, and best wishes on your efforts!
Jhess is offline   Reply With Quote
Old 12-20-2017, 04:50 AM   #11
1987 25' Sovereign
Blairstown , New Jersey
If you are considering replacing the floor look at the Coosa Bluewater 26 rather than new plywood.
Robertone139 is offline   Reply With Quote
Old 12-20-2017, 12:01 PM   #12
duncans's Avatar
1973 31' Sovereign
Meant : Can of Beans
Merry Christmas!
Old 12-20-2017, 12:02 PM   #13
1976 31' Sovereign
Mill Valley , California
I have a 76 sovereign and am a bit ahead of you, having repainted frame and rebuilt windows, and front and back floor. Now working on plumbing and electrical. I found that I lost a lot of time and can do additude searching the forums. I suggest you find one or two people who have done the work to be one on one go to for support and questions. If you are like me and learn better from others rather than reading I guarantee you will save energy.
If you private message me I am happy to have a phone chat with you.
GiftingGirl is offline   Reply With Quote
Old 12-20-2017, 03:32 PM   #14
1973 31' Sovereign
Richmond , Virginia
I will PM you, thanks so much. That’s exactly my predicament, I absorb info so much better from being told rather than reading.
Old 12-20-2017, 03:39 PM   #15
1973 31' Sovereign
Richmond , Virginia
I’m going to make an effort to keep my progress and process posted here as well.
Today I was able to cut out the center of the subfloor and remove all the insulation. I also removed the banana wrap and disconnected the bellypan from the body to get access to to the frame and elevator bolts and remove the rest of the insulation.
Next step will be bracing the body with 2x4s and removing the rest of the elevator bolts and subfloor, and dropping the pan entirely. I know I’ve got some crossmembers to replace but I’ve got a guy to help with that so I should be okay there.
Advice on removing the elevator bolts in the end pieces would be appreciated, I was cutting off the pan head from the bottom but without the c channel these are sunk into the plywood and so I think I need to cut them from the top, out of the u channel.
Old 12-20-2017, 03:40 PM   #16
1973 31' Sovereign
Richmond , Virginia
Here are some photos from today.
ID:	301201   Click image for larger version
Old 12-23-2017, 03:45 PM   #17
1973 31' Sovereign
Richmond , Virginia
Trying to beat a cold front coming through, I’m afraid today was probably the last of our good weather.
Decently solid day though. I got the shell braced and the rest of the subfloor removed. I used a Dremel tool with a carbide blade to cut out the elevator bolts and wood screws. Fairly painless process. Just slid it under the u channel. Also got the outside power washed.
Fans have arrived, two fantastic fans with smoke lids and one Maxxfan 7k. I’m thinking that one will go in the rear (bedroom) and the other two up front.
Ordered a bunch of window supplies and a buck riveting kit.
Need to order a new AC unit and figure out what I’m doing about solar.
Still feels like too much to do but considering we’ve only had her for two weeks I think we’re doing ok.
Old 12-23-2017, 09:28 PM   #18
2003 25' Safari
I’d say your doing great. It will all be worth it
Old 12-24-2017, 08:52 PM   #19
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
Images: 48
I didn't like the tail if ours dragging every time we left the driveway, and I really dislike the portable gray tank, so I solved both at the same time. Or as soon as I put the plumbing in it will be.
I'm busy waiting for help to hold the bucking bar. Currently
Do the floor and frame before re sealing, it may get tweaked from lifting
Can of beans is offline   Reply With Quote
Old 12-29-2017, 05:00 PM   #20
1975 27' Overlander
Toronto , Ontario
Nice work on this project. I totally understand how you must feel. I purchased a 1975 27' Overlander in May and redoing everything myself as well. I am a hobby woodworker and know how to work with wood. Purchasing this Airstream definitely has given me a whole new perspective on aluminum materials ha-ha.
Feel free to follow along on my progress here: http://www.airforums.com/forums/f36/...er-169972.html or via Instagram https://www.instagram.com/stormytheairstream/
Feel free to PM me anytime with any questions you may have, I might have the answer.
blackbear is offline   Reply With Quote
sovereign
New member in MN hoping to learn a thing or two OakCreek Member Introductions 13 12-20-2012 04:01 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
Newbie hoping to be a future owner LPMM Member Introductions 3 11-28-2006 07:16 PM
Hoping to be on the Road! Morningside Member Introductions 2 10-01-2006 10:28 PM
Hoping to buy my first "baby" this month! need advice!!! virgin Our Community 3 07-22-2003 10:30 PM
