A set of keys to my 25' 2013 International was stolen from my TV (they stole my TV as well but I have recovered that). I would like to rekey/replace the deadbolt and lock to storage compartment. Any advice on how best to accomplish that? Thank you in advance.
2016 28' International
2015 28' International
2013 28' International
Las Vegas
, Nevada
If you have an old school locksmith nearby they can re-core both the dead bolt and cargo. Otherwise you will have to order a new deadbolt assy. from AS, but you are out of luck on the cargo lock assy. as these have been out of stock for a couple of years now, I called every dealer in the US and found the last 2 cargo lock assy.'s in Idaho. AS has a retrofit for the cargo locks that requires a lot of modification to the existing cargo door that it makes more sense to replace the whole door ($650).
Thank you Vintagemotor. I will check on a locksmith, but will probably end up buying the deadbolt assembly. May just take my chances on the cargo lock, not much to it to keep someone out that is determined to get in. Thanks again.
