Old 08-04-2018, 10:45 AM   #1
harryk's Avatar
2005 31' Classic
Venice , Florida
Need help with electric tongue jack
2005 Airstream 31 Classic...have a Barker Industries H & H 3500 # tongue jack.
Acts like the limit switches are broken...blows fuse if you go full up...or if you go full down.
Can you please tell me if it has limit switches. If it does, how are they accessed ? Took the top cover off which gives access to the motor and the up & down switch. Removed the 2 screws going up from the bottom & I expected the case to come apart...it did not
Need help at this point.
harryk is offline   Reply With Quote
Old 08-04-2018, 11:24 AM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
This reference page might help. Not sure exactly how the newer jacks work, but the older ones like on our 1987 Avion had limit switches.
http://www.barkermfg.com/uploads/5/4...p_3500_all.pdf
Maybe this contact information can direct you to someone who can help from Barker:
1125 Watkins Road / PO Box 460
Battle Creek, MI 49016
Phone: 269-965-2371 Fax: 269-965-2389
www.barkermfg.com E-Mail: service@barkermfg.com
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 08-04-2018, 11:47 AM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Any other history?
Was working fine and then started acting up?
Removed head for any reason?
Look at the post, is it visibly bent?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-04-2018, 11:48 AM   #4
CruizinDux's Avatar
Tracktown USA , Oregon
Note my jack is the Barker 3000 but may still apply.
check out this link and my post #7
that discussion is in regards to greasing the barker but contains a link at the bottom re re-sequencing.
http://www.airforums.com/forums/f44/...be-183854.html
for some reason the link in the above post is not working. This link post #50 is the re-sequencing instructions that Barker sent me. They never did answer re the limit switch (and simply send me a new head) so my takeaway was No switch...just methodology.
http://www.airforums.com/forums/f44/...-151073-4.html
hope this helps
CruizinDux is offline   Reply With Quote
Old 08-04-2018, 07:46 PM   #5
Leilanisteve's Avatar
2015 19' International
Boise , Idaho
I contacted the Barker company directly a few weeks ago to explain my issue on my jack. I was thinking it was a failing switch which the representative confirmed. I installed the new new switch he sent and it works well now. Not saying a new switch will work for you but speaking with a customer service representative was easy and helpful.
Steve
Leilanisteve is offline   Reply With Quote
Old 08-04-2018, 10:21 PM   #6
CruizinDux's Avatar
Steve
Steve was this a limit switch or the on/off? I was under warranty and was calling because the dealer declined under warranty. I kept asking Barker about the limit switch as I did not see it on the parts list/schematic and they kept saying re-sequencing...heck we'll send you a new head. Never got a definitive answer re the limit switch.
b
Old 08-05-2018, 05:36 AM   #7
Boise , Idaho
It was the on/off switch.
Old 08-05-2018, 05:49 AM   #8
harryk's Avatar
2005 31' Classic
Venice , Florida
Tongue Jack
Thank you all for your replies. Yesterday, I finally found my jack on the internet by typing in Barker "superjack" instead of Barker 3500# jack. (cannot find model # on jack) That being said, they are saying remove the cover by removing 4 screws underneath (which I did) & "tapping" around the base. I guess they know its either painted or corroded shut.
And the schematic shows limit switches.
Will try again next couple days and will repost.
Old 08-05-2018, 06:07 AM   #9
Boise , Idaho
I was grateful to have an extra set of hands/eyes while replacing my on/off switch. Take pictures of the wiring before you disconnect anything. We disconnected and reconnected one wire at a time which was helpful for not getting confused. The light and on/off switch were accessible under the main cover but I didn’t see any other switches just under the cover. If the limit switch is deeper accessibility could be an issue.
Steve
Old 08-05-2018, 06:15 AM   #10
GCinSC2's Avatar
If the Barker refuses to cooperate, the Husky jack has got a pretty good following and comments.
S/OS #001
Old 08-05-2018, 06:59 AM   #11
PaulnGina's Avatar
Good Ol' , USA
Glad you figured out which model you have. I thought maybe yours was the newer model (the Barker 3500#), but you have the same as I do. It's about time for me to clean and relube ours.
1987 Avion 34W
Old 08-05-2018, 11:21 AM   #12
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
I replaced mine with a Huskey 5000#. Never looked back.
jimfa440 is offline   Reply With Quote
Old 08-05-2018, 12:32 PM   #13
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Yes - Husky replacement. There is a piece of my thoughts that is guilty on two points. The Husky is not "Made in the USA" and repair seems more frugal than replacement. My deciding logic was that having to replace/repair a product after 3 years did not meet my expectation of a good product. That also tainted my perception of the better jacks which Barker sells. Changing products nixed the fix what you got logic, so we moved on.
The Husky is slower. That is offset by quieter operation. Time will tell if it is a better product or just different. However, that silver paint goes quite well with AS aluminum. Pat
Old 08-05-2018, 01:36 PM   #14
GCinSC2's Avatar
It took a bit of looking but I installed my Husky in 2013. I had already replaced the switches in my then 6 year old original jack. The Husky has required zero service so far. I think they hit on a darn good idea when they utilized a ball screw drive and my rig is pretty heavy in the hitch at hook up time. I've never even used the manual override.
S/OS #001
Old 08-05-2018, 02:58 PM   #15
PKI
PKI's Avatar
Originally Posted by GCinSC2 View Post
-- snip -- good idea when they utilized a ball screw drive -- snip --.
I think they did too. That was a major justification for buying it. Thanks for the reliability info. Pat
manual crank for 1964 electric tongue jack Croverlander 1960 - 1964 Overlander 15 04-09-2014 11:10 AM
Installing a new ultra 3002 electric tongue jack on my 65 Caravel toastie Jacks, Stabilizers, Lifting and Leveling 3 03-15-2007 11:10 AM
Electric tongue jack help RVnDixie All Argosy Trailers 8 12-31-2006 08:54 PM
Electric Tongue Jack darryl97420 Jacks, Stabilizers, Lifting and Leveling 0 05-25-2006 08:57 PM
Electric tongue jack not extending ipso_facto Jacks, Stabilizers, Lifting and Leveling 5 03-25-2003 11:58 AM
