Old 06-13-2017, 10:09 AM   #1
John Rousch's Avatar
1969 27' Overlander
Sebring , Florida
Need help with '69 overlander AC unit shroud
AC unit question for 69 Overlander
I posted this also in the Overlander forum, but I thought I'd ask the general group.
Here is the photo of the AC unit on top of my '69 Overlander. I believe it is the original unit. The manufacturer's plate says (Which I took off to be able to recover the data):
Summer Air Conditioner for Outdoor Use
Model: TAC-110-1 Series DA-9
Part: 258150 Serial 48764
Made by Armstrong Furnace Company, Columbus, Ohio.
Question is: Does the replacement shroud need to have an opening on the over the shroud for the fan, or can it be solid?
The reason is I'm still getting leaks and sealed up everything I can think of on the roof. I wonder if it ls leaking through the AC fan opening going down into the unit.
Anyone out there have some insights?
Name:	AC unit 69 Overlander.jpg
John Rousch is offline   Reply With Quote
Old 06-21-2017, 09:07 PM   #2
1969 27' Overlander
Sebring , Florida
Bought a generic replacement shroud, modified it, now installed, all is well
Wanted: Shroud / Cover for Rooftop A/c Unit Eric111 Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-01-2017 07:27 PM
New shroud or new unit? armstrong TR21-12 RaleighAir Furnaces, Heaters, Fireplaces & Air Conditioning 12 02-23-2011 04:02 AM
1976 overlander a/c shroud' cottontop Furnaces, Heaters, Fireplaces & Air Conditioning 7 10-26-2009 10:14 AM
Need to replace airconditioning unit need help... retrocowgirl Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-16-2006 09:15 AM
