04-23-2015, 11:14 AM
#21
1977 31' Excella 500
Berkeley Springs
, West Virginia
They used to have thousands of square feet of aluminum honeycomb flooring at the Boeing Surplus. I wish I had bought a bunch of it when I worked out there. Super light, super strong, should last forever. But they've closed the place down.
I just did a porch with Trex decking and it made a nice job. But it's really heavy.
I agree with the above. Plywood done right will last. Start with Marine Grade, then varnish it on both sides with something good like Valspar Exterior Spar Varnish.
A trick that Avion did to help their floors last (they were two layers of plywood with a layer of insulation between) was to take the linoleum across the top of it, wrap it down over the sides and come in a few inches and staple it on the bottom. That helps to keep the edges dry. Then they'd put carpet or whatever over top the linoleum. It helps.
- Jim
04-23-2015, 12:58 PM
#22
1999 34' Excella
Hillsboro
My brother is in the Louisiana oilfield and goes thru lots of steel. His recommendation is "US Steel...if you can find it.
Peace and Blessings..
Channing
WBCCI# 30676
04-23-2015, 01:35 PM
#23
1974 27' Overlander
Portsmouth
, Virginia
I think it will be plain old painted steel and plywood for me. Pretty much all travel trailers are made that way and the only ones that have problems are from roof leaks. Actually the plywood floor in my Airstream wasn't that bad, only a small amount of rot from window leaks around the edges. The frame rusted out so bad because it was parked next to the Atlantic Ocean for 40 years.
I took Bob's advice and called Hibbard's Iron Works in Newport News. I went by there and they are trailer people and seemed to understand what I was looking for and willing to do it. Now I'm just waiting for a price but I think they will more than likely be the ones. Thanks Bob!
05-14-2015, 05:13 AM
#24
1974 27' Overlander
Portsmouth
, Virginia
Frame found!
05-14-2015, 05:51 AM
#25
Portsmouth
, Virginia
Not a bad idea at all. Save the windows and doors and you may recoup your 400 bucks pretty quickly. The tanks might be worth something as well. Looks like there is not much holding it together at this point anyway. What kind of axles does it use?
05-14-2015, 06:53 AM
#26
1964 26' Overlander
Richmond
, Virginia
don't forget to potentially save the appliances as well for resale.
05-20-2015, 11:25 AM
#27
1974 27' Overlander
Portsmouth
, Virginia
Short video, mainly because I wanted to try out my new Gopro. Sorry, no narration I feel stupid talking to myself Anyway you can see my progress on the trailer frame.
https://youtu.be/O_ALIP_4GPs
05-21-2015, 06:39 PM
#28
Berkeley Springs
, West Virginia
Nicely polished shell there! And the frame is coming along nicely. But, what is that Square Box of Blasphemy in the video??!!! You know we are Silver Trailer Snobs around here
Just teasing dude! Keep up the good work!
- Jim
05-30-2015, 02:36 PM
#29
1974 27' Overlander
Portsmouth
, Virginia
05-30-2015, 05:13 PM
#30
Portsmouth
, Virginia
So what kind of mods if any did you do to the new frame to make it fit the airstream?
05-31-2015, 02:48 PM
#31
1974 27' Overlander
Portsmouth
, Virginia
Airstream Jenga
06-01-2015, 01:50 PM
#32
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Yeah! Nothing scarier than moving the shell - and wind? Actually saw one person who failed to brace and tie down his shell LOSE it in some high gusts. Now make sure you get the screws in securely and the rest is minor (Well that's misleading, EACH of the remaining 8000 things you have left is minor, but the totality is overwhelming.).
Paula
