Old 03-23-2020, 12:38 PM   #1
1977 31' Sovereign
Lake Worth , Florida
Need A/C info
I just bought a project and need to replace the air conditioner. I have a 1977 Sovereign 31' and need to know a few things. Do I need a specific ac unit for this? The original was a 13,500 BTU, is that enough or should I go larger? Any specific brand better?
Thanks for any help
brightpeeps is offline   Reply With Quote
Old 03-23-2020, 01:36 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
I am not an AC specialist but you may be able to measure the opening and go from there. Can always widen the opening. But thatís a whole project all in itself. If youíre not widening then that bad boy is going to restrict your options. Once you have the opening size you can look at all of your modern options that will fit that size and choose the best BTU from there
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 03-23-2020, 01:42 PM   #3
1986 31' Sovereign
Miami , Florida
If it doesnít cost significantly more, then I would recommend a 15k BTU unit. We have a single 13.5k on our 1986 31í and it struggles when the temp outside is above 90.
If you are installing a new Dometic, which uses cups to catch the condensate, be sure to order and use TWO gaskets so you donít damage the cups when you cinch down the a/c.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
n2916s is online now   Reply With Quote
Old 03-23-2020, 01:43 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Going with a rooftop RV air conditioner the newer ones, at least, all fit in the same size opening which, I think, is 14x14 inches. Depending on your camping area, a 15,000 BTU unit might be the best bet. I have a 13,500 unit in my Classic 30 and, living in Florida, would like to have more capacity either in the form of a bigger unit or another unit in the bedroom.
Choices are limited. Dometic has several lines. Search the AC subforum on here to get an idea of what people like and don't like.
Al
Al, K5TAN and Missy, N4RGO
WBCCI 1322
Old 03-23-2020, 02:03 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Back in 2004 when I ordered my 31' Classic SO. 13.5 K was the standard. 15K units were optional and when placing my order I went for the 15K unit. I never have regretted that choice.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-24-2020, 12:05 PM   #6
1977 31' Sovereign
Awesome, thanks everyone.
Your Bank Info may be public info HowieE Off Topic Forum 6 09-16-2014 12:48 PM
wow info overload/Classic info wanted SterlingSRCH Classic Motorhomes 7 02-15-2013 08:41 AM
need info on repainting my Argosy Tikihut Our Community 8 03-12-2003 10:01 PM
Need info on A/C unit on a 1975 26 ft Argosy ... Hayseed Argosy Motorhomes 0 06-27-2002 08:19 AM
