Old 04-25-2019, 07:51 AM   #1
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
My first popped rivet
I suppose it had to happen sometime. Just discovered my first popped rivet above my sky window in my 2019 FC26.
Do I just clean it out and install a new rivet? Size?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 04-25-2019, 07:58 AM   #2
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
The more you use your trailer the more you (might) find this happening....
Very easy fix. Just pop a new rivet in and your done. 1/8 inch diameter aluminum with aluminum mandrel. Home Depot has them.Drill out the remains of the old one and put a new one in.
Hope this helps
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 04-25-2019, 08:08 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Can't help you with the size as Airstream replaced my single popped rivet, but I can tell you how to minimize it. Mine is 15 years old and popped one at 5 or 6 years old and so far have not popped any.
I see you have a 3/4 ton, it's not as stiff as a 1 ton, but I put this on my 3/4 ton truck:
https://airsafehitches.com/receiver-hitch/
And I put these on the Airstream:
http://www.centramatic.com/wheel-bal...Number=200-223
You will also find that the ride with the Airsafe hitch is much softer in the truck as well.
Old 07-30-2019, 05:16 AM   #4
2007 23' Safari SE
Woodstock , Connecticut
Hope this helps
Doug
I have 23ft safari. Popped refits interior. What exactly are you drilling out the remains of? The mandrill, the stud, what please???
Curtis
airforus is offline   Reply With Quote
Old 07-30-2019, 05:51 AM   #5
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Yes drilling out the stud. When the head of the pop-rivet breaks off the “shaft” of the rivet can be lodged in the hole. This will need to be removed before a new rivet can be put in place. This can be done by using the correct size drill bit. (1/8th”) for inside rivets. Be careful not to enlarge the hole while drilling the old rivet out. Light pressure works best.
Old 07-30-2019, 07:19 AM   #6
Arcticfox's Avatar
Central , Canada
Hi Curtis
I think GMFL has articulated this as good (if not better) than I could have. If you have any other concerns or questions just yell.
Cheers
Doug
Old 07-30-2019, 08:41 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
When drilling be careful not to go too far so you hit the outer skin.
A couple of rivets on mine popped are than once and the holes became slightly enlarged. I used 5/32" instead of 1/8" for those. I got the 5/32" on Amazon they were not carried by anyone locally.
2019 Ford Expedition Platinum
Old 07-30-2019, 09:28 AM   #8
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
When this rivet pops again... consider blemishing the interior with a Lathe Screw. Available at major hardware stores in several lengths. They look nice to me and work.
They are used on $1 million race cars to secure plexiglass windows, from my observations.
Airstreams are hand made. The inside aluminum skin is not necessarily snug against the metal ribs that are riveted. It can be FLUSH, or have an air space. Not a guess on my part as I have experienced popped rivets in chronic weak spots within an Airstreams contours.
As this is considered unethical in the Airstream Beauty Salon... the Lathe Screw needs a well charged battery drill with Philips Head. When these torque solid... they can handle lots of stress. I have never needed to remove the remaining pop rivet still within the frame, behind the aluminum skin. These screws are aggressively threaded and a serious option.
If a pop rivet pops. Replace and it pops. Maybe... it will be too late by drilling out the hole with a large pop rivet. No one ever noticed my Lathe Screws. Steel and the same color as the aluminum within. Just with a flange that prevents the rivet hole to tear.
Just my advice. Do not take it now. You will later.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 07-30-2019, 09:36 AM   #9
eagletoo's Avatar
2020 23' Globetrotter
Long Island , New York
Ray, what size screw? #8?
Bruce
2020 23’ FB Twin Globetrotter Natural Elm/London Grey
2018 Jeep Overland 5.7L Hemi
I’d rather be camping is an understatement!
eagletoo is online now   Reply With Quote
Old 07-30-2019, 10:10 AM   #10
Ray Eklund's Avatar
I kept some Lathe Screws, but gave the new owner the cartons. I made a scan of the two lengths compared to a nickel... if that helps.
The curved sections that popped rivets were more likely needing the longer of the two, due to a gap of air space to the frame. They are sold by the carton at Lowes or Home Depot. If you use them on a fancy, expensive car... they sell them one at a time. Same screw. Imagine... that?
ID:	348012   Click image for larger version
Human Bean
Old 07-30-2019, 10:23 AM   #11
eagletoo's Avatar
Appears to be ¾ and ½ long. #8 it also looks like. Thank you.
Bruce
Old 08-02-2019, 04:44 AM   #12
2007 23' Safari SE
I called the mother ship for the size rivet. Was told they use 30bit metric. Would this be the same size as 1/8th?
Curtis
Old 08-02-2019, 05:05 AM   #13
Wayne&Sam's Avatar
Images: 21
Originally Posted by Ray Eklund View Post
Steel and the same color as the aluminum within. .
steel + aluminum = galvanic action. That's why it is stressed to get aluminum rivets with aluminum mandrels.
Old 08-02-2019, 05:16 AM   #14
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Curtis
1/8th” is correct 0.125”
#30 metric 0.128”
If you want to get super technical, let’s just say the standard 1/8th” bit will help prevent you from enlarging the hole...
Old 08-02-2019, 11:44 AM   #15
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
Airstream life has a great Rivet repair kit that includes a rivet gun with adjustable head made by the same company that makes Airstream’s rivets, and an assortment of rivets that Airstreams use, like the belly pan. Plus a how to guide...
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Old 08-03-2019, 09:41 AM   #16
Summerfield , Florida
Cool Galvanic Corrosion
Galvanic Corrosion (also called ' dissimilar metal corrosion' or wrongly 'electrolysis') refers to corrosion damage induced when two dissimilar materials are coupled in a corrosive electrolyte. It occurs when two (or more) dissimilar metals are brought into electrical contact under water.
Just replaced mine. Inside next to bathroom bulkhead. Went with a steel rivet. I hope I won't have it underwater.
Pubtym is offline   Reply With Quote
Old 08-03-2019, 10:47 AM   #17
FishByFly's Avatar
Fort Worth , Texas
“Galvanic corrosion occurs when two materials (an anode and a cathode) (dissimilar metals) come into contact with each other and an electrolyte. Electrolytes can be environmental factors such as humidity or rainwater.”
Likely all is good as long you keep air away from the location...
FishByFly
because I catch fish on a fly...
2017 25' Safari FB - “Fly Fish Inn
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 08-03-2019, 12:00 PM   #18
Ray Eklund's Avatar
Performance Metals Products: (Primarily boats... but informative.)
Sacrificial Anodes FAQs
Q. What metals are sacrificial anodes made from?
A. The three most active materials used in sacrificial anodes are zinc, aluminum and magnesium. They have different properties and uses.
The aluminum Airstream body is attached to an iron frame with iron bolts.
Some of you may have a gold crown on a molar. If you, by accident, touch this gold crown with a stainless steel fork while eating... you will understand what previous posters are explaining. Also the flow of electrons. Yikes...
An aluminum can, all by itself will corrode on the ground. So will an Airstream sitting, over time.
Filiform may be the beginning which I have not heard much about lately with salt from the friendly 'ocean breezes' and mist along the coasts. Another example of corrosion.
Myself... I will use lathe screws on my Airstream's interior. If it is that damp within your Airstream... you have bigger issues. But a great conversation, non the less. That is what is nice about a diversified community.
Human Bean
Old 08-23-2019, 02:35 PM   #19
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
Another Rivet Question
For my 2018 FC23FB, my repair manual lists three interior rivets. Those are: AD43ABS (1/8x.337), AD45ABS (1/8x.462) and AD48ABS (1/8x.650).
Airstream Supply has the #45 replacement rivets in their kit with the appropriate #30 drill bit which I purchased.
I had a rivet break loose from inside the bulkhead above the stove. Using a flashlight with a magnifying glass I couldn't see much of anything to tell me the length of the replacement rivet to use.
I was able to drill out the old rivet and used the drill bit as a guide as to the grip range needed for the replacenent rivet. The short rivets definitely would not work.
I used #45 rivet from Airstream Supply kit. That seemed to work.
My question is if there are three interior possible replacement rivets is there a manual that indicates which number goes where?
No one has definitely answered this question with manual data.
Looks like it's a guessing game here.
Randy
Name:	Skin Rivets.jpg
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Old 08-23-2019, 04:52 PM   #20
Portland , Oregon
I just spent two weeks with my Brother-in-law, camping and fishing in Montana. I used a friend's 25' 1992 Excella and he was camped in his 5-year old "Sheep-Herders" style trailer made in Utah.
He knows we're on a trajectory to purchase an Airstream, most likely a 25'.
He recently retired from 30 years as civilian aircraft mechanic/supervisor working on the A-10 Warthog.
Knowing of our intent to purchase an Airstream, we talked a lot about the properties of Aluminum and its interactions with other materials. One key issue he highlighted is their finding that over-time, if Aluminum has continued direct contact with any Carbon containing material (e.g. Carbon steel bolts, washers, nuts, etc.) it can result in corrosion, weakness, and failure of the Aluminum. He said it took years for the engineers to figure this out, but once they did they completely altered the technical standards and protocols for the fastening systems they use on the A-10 and now prohibit the use of any Carbon containing fasteners or other connections directly to the Aluminum components on the A-10.
I assume Airstream doesn't follow this protocol, but for any repairs, etc. that I do on our Airstream I will certainly be mindful of the hard-learned knowledge from the Air Force aviation engineers and mechanics with many years of experience working with Aluminum.
Cheers,
Bryan
blacklab is offline   Reply With Quote
Interior "popped" rivet replacement? MAJORJDB General Interior Topics 11 04-16-2016 07:35 PM
Popped rivet near the top door Hodum Ribs, Skins & Rivets 3 02-21-2012 09:53 PM
Popped a rivet horse sense Ribs, Skins & Rivets 11 04-01-2010 05:58 PM
Popped rivets, repair and prevention Boondocker General Interior Topics 26 11-28-2005 04:57 PM
12v reading lights '65. popped out ronmcor Electrical - Systems, Generators, Batteries & Solar 4 11-29-2004 07:07 PM
