Old 10-20-2016, 02:00 PM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
Magic Chef Door Question
How do I release the spring tension on my oven door to get to the screw that holds the door hinge to the cabinet?
Picture shows the screw has backed out and the door droops to a point I can't get a screw driver on it.
2004 Excursion 4x4
Old 10-20-2016, 04:12 PM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Have you tried an offset or ratcheting screwdriver?
We had a Majic Chef in our last trailer and I seem to rember that ther may be a way to disassemble the door - that may allow you to get to the spring tension. Otherwise, you may have to pull the stove out of the cabinet to access other hidden screws.
Bummer...good luck!
Shari
Old 10-20-2016, 04:25 PM   #3
HowieE's Avatar
Images: 12
Tried that. The unit is slid out a few inches but no access from that side.
I am afraid there is a captive nut in the oven frame for the screw in question. If so it may be a tuffy..
2004 Excursion 4x4
Old 10-20-2016, 04:46 PM   #4
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
You put two pin in that round hole shown in your picture. Then the door will slide up out of the hinges.
sgschwend is offline   Reply With Quote
Old 10-21-2016, 09:11 AM   #5
HowieE's Avatar
Images: 12
If you mean these holes it doesn't seam to offer any way to remove the door. I have included a picture of the other side of the door and note the spring arm is screwed to the door frame. I don't even see how they made it let alone take it apart.
ID:	273914   Click image for larger version
2004 Excursion 4x4
Old 10-21-2016, 11:21 AM   #6
1978 Argosy Minuet 6.7 Metre
Skamokawa , Washington
Maybe these pics will help.😎
ID:	273919   Click image for larger version
sherry23bee is offline   Reply With Quote
Old 10-21-2016, 11:40 AM   #7
HowieE's Avatar
Images: 12
Thanks but it looks like a different model.
2004 Excursion 4x4
Old 10-21-2016, 12:13 PM   #8
reddogfox's Avatar
2008 20' Safari SE
Thumb Area , Michigan
HowieE
I had the same oven door mount screw loosen on my trailer several years ago. As I remember I solved the problem by lifting the door at the hinge corner while a helper tightened the screw. If this works for you also check the tightness of the two screws on the bottom of the oven door.
Richard from MI
20' 2008 Safari SE, Dill TPMS Silver Dog House
2007 GMC 1/2 ton Sierra ARE Cap
AIR # 10494
reddogfox is offline   Reply With Quote
Old 10-21-2016, 12:15 PM   #9
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
stove screw
try to find wrenches like this;about 3.5 " long. the yankee is a stanley
joe q
joqin is offline   Reply With Quote
Old 10-21-2016, 01:58 PM   #10
HowieE's Avatar
Images: 12
I have been using a Chatman off set screwdriver.
The problem is growing. Looks like the oven body holes have stripped. I tried some sheet metal fillers but need to fix the door in position to remove the spring tension and free up a hand.
Had the over pulled out a few inches but no access from the sides so it is back mounted in place.
2004 Excursion 4x4
Magic Chef needs magic fix Sheridan Stoves, Ovens & Microwaves 8 11-21-2009 03:44 PM
Magic Chef oven door brwarriors Stoves, Ovens & Microwaves 5 06-14-2007 01:17 PM
Magic Chef Oven Door John Sims Stoves, Ovens & Microwaves 1 10-18-2004 07:06 PM
Magic Chef Oven Door Dharma Stoves, Ovens & Microwaves 2 07-08-2004 06:04 PM
