Old 07-30-2018, 04:40 PM   #1
Luminous
LY007's Avatar
1983 27' Excella
Vesuvius , Virginia
Low AC Voltage and Dometic Frdge Performance
I have a 2 year old Dometic and have been pleased with it.
This weekend we were camped at a music festival where they used big towable generators and spider boxes. As more people plugged in, the line voltage dropped from 120v to a steady 109v.
And my fridge was pretty much at 45 degrees instead of its usual 39.
Coincidence, or was it a consequence of sub nominal voltage?
Steve
83 Excella 27
07 Tundra Limited
LY007 is offline   Reply With Quote
Old 07-30-2018, 04:44 PM   #2
2007 22' International CCD
IMHO, consequence. On AC power, the fridge uses a resistance heater powered by line voltage to boil the coolant that makes the fridge work.
Low line voltage implies low heat output for the heater coil. Switch to propane if you have that option...
Some Dometics automagically switch to AC line voltage in an attempt to save propane. They don't seem to cool that well when they do that. On mine, you can force it to stay on propane by switching out of "Auto" to "Gas", IIRC.
rmkrum is online now   Reply With Quote
how low is too low AC voltage? WineStream Electrical - Systems, Generators, Batteries & Solar 64 07-16-2018 08:57 PM
Low voltage and surge protector pjmoser Electrical - Systems, Generators, Batteries & Solar 3 10-20-2014 11:17 AM
1968 Airstream Tow Vehicle Connection and Low Voltage Schematics BuffaloJoe 1965-1969 Sovereign 2 05-26-2013 07:46 PM
what do the M and S represent on the low voltage schematic? advent Batteries, Univolts, Converters & Inverters 10 04-15-2010 08:43 AM
