Old 09-15-2021, 09:29 PM   #1
California , California
Lost keys to coupler barrel lock
I posted awhile back about having lost all our keys when our truck was broken into. I was able to get replacements for everything but there's still one issue left. We have a barrel lock on the coupler latch, like this one:
Advice on YouTube is geared toward hitch lock removal where they basically hammer it out. That doesn't seem like an option here without damaging the coupler. Is a locksmith the best option for this?
tommysully is offline   Reply With Quote
Old 09-15-2021, 09:35 PM   #2
2020 19' Caravel
Ammon , Idaho
A good locksmith is likely the best option for a non-distructive solution.
OutdoorIdaho is offline   Reply With Quote
Old 09-15-2021, 09:36 PM   #3
2018 27' Tommy Bahama
Los Osos , California
We have the same lock. The keys are numbered - if you remember the number, I imagine you can get a replacement.
If not, a sawzall will remove it in about five seconds without damaging the coupler.
Jeff
JeffE is offline   Reply With Quote
Old 09-15-2021, 09:56 PM   #4
Jeff
I was wondering about sawzall but didn't know how it'd do on the metal in this lock.
Old 09-15-2021, 09:58 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
An angle grinder with a cutting disk will take it off
CRH is offline   Reply With Quote
Old 09-16-2021, 09:42 AM   #6
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
even the best high end bike locks dont last more than 60 seconds when cut with an angle grinder ....it will remove that in a flash with no damage if your careful.....probably can buy one for the cost of a lock smith.
rucos is offline   Reply With Quote
Old 09-16-2021, 09:50 AM   #7
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If you go the angle grinder route, do be careful. You will be through the lock quicker than you think. It's amazingly easy to "bump" the tongue once you go through .....
Old 09-16-2021, 11:20 AM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Harbor Freight has good enough for at least one use grinders probably under $20
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 09-16-2021, 11:47 AM   #9
2014 27' Flying Cloud
Wenatchee , Washington
Ö If not, a sawzall will remove it in about five seconds without damaging the coupler.
Thatís what I did a few years ago when I had that problem. It didnít take more than five seconds to get the job done (and no collateral damage either).
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 09-16-2021, 11:48 AM   #10
2020 23' Flying Cloud
San Antonio , Texas
The sawsall is the best way, a locksmith will cost three time the cost of a new lock.
Old Fart is offline   Reply With Quote
Old 09-16-2021, 12:29 PM   #11
ITSNO60's Avatar
Tucson , AZ
Another option is to drill out the lock cylinder if you don't own a ginder or sawzall or are inexperienced in their use. A big drill and work up to a 1/2" bit will do it while someone holds it from spinning with channel locks. Grinder is still best but can be dangerous if inexperienced with one.
Brian
ITSNO60 is offline   Reply With Quote
Old 09-16-2021, 12:47 PM   #12
Hi
Yeah this is exactly what I'm worried about. Apply a little too much force and I'm going to really mess up the tongue.
Old 09-16-2021, 01:21 PM   #13
Half a Rivet Short
2022 Interstate 24X
HI
One option not yet mentioned is a cutting disk on a Dremel tool. It's not any cheaper than the other alternatives. It may be slightly easier to control. The disks can shatter so it's best to use a face shield .....
https://www.amazon.com/Dremel-420-He...1819944&sr=8-9
Old 09-16-2021, 01:30 PM   #14
WHUDS22's Avatar
2018 25' Flying Cloud
Arcadia , Oklahoma
Jeff
or grinder if careful
WHUDS22 is offline   Reply With Quote
Old 09-16-2021, 01:31 PM   #15
WHUDS22's Avatar
Arcadia , Oklahoma
HI
yes they shatter I went through 3 on a job once
Old 09-16-2021, 07:43 PM   #16
PC Conner's Avatar
2018 27' Flying Cloud
INDIAN HARBOUR BEACH , Florida
I would add to Brian's suggestion--use vice-grip pliers vs. channel locks. That will hold the lock securely without having to keep pressure on the pliers.
I have a Dremel tool and am sure it would do the job--but wear safety glasses (but I don't always), for either sparks or pieces of the cutting wheel.
PC Conner is offline   Reply With Quote
Old 09-16-2021, 08:16 PM   #17
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
HI
Yes, this. I cut a padlock off of my coupler with a Dremel. Easy to control. And it took less than 10 seconds. Once I realized how quickly and easily they can be cut, I now just use a $2.00 pin.
thewarden is offline   Reply With Quote
Old 09-16-2021, 09:09 PM   #18
CRH
1995 25' Excella
xxxxx , xxxxxx
I once watched a man cut down a basketball goal post with a Dremel and a few cutting disks. I was impressed.
Old 09-17-2021, 07:49 AM   #19
Half a Rivet Short
2022 Interstate 24X
Hi
Those little disks are impressive. I'm sure there is something out there they will not slice through. Whatever that is, I have not run into it yet. They have quickly gone through every lock / chain / cable / bolt I've ever attacked with them. It might take a couple disks, but they are cheap.
Every time I see anybody talking about their "impossible to defeat" lock I remember these little disks......
Old 09-17-2021, 08:29 AM   #20
Mollysdad's Avatar
How would a thief remove it?
A 3' piece of pipe slipped over the lock and a sharp bend. The shaft snaps right off.
'68 Bargman L-100 Barrel Lock TCTradewind Doors & Locks 6 09-01-2021 07:30 PM
new never used proven industries trailer coupler lock 2 5/16" Trailer Coupler Locks Model 2516 AS jackvosney Airstream Classifieds 2 08-17-2020 10:26 AM
'79 Safari with Keeler Lock made by GM: keys lost willowdial Doors & Locks 1 09-14-2012 01:55 PM
'65 GT Main Door Lock / Lost Keys Chiefy Doors & Locks 3 01-10-2010 04:34 PM
