08-10-2018, 10:26 AM
1965 22' Safari
Boulder Creek
Looking for 1965 Safari roof vent cover
Hello I own a 1965 Safari. I recently took it on its maiden voyage from the Bay Area to Seattle WA. It was a ton of fun, until my middle roof vent cap blew off in transit on I-5 as I was driving through Portland. I didn't realize it until our next camp spot. I have called Inland R.V. with no luck. Does anyone have any advice on obtaining a vent cover or any good alternatives for replacement. Thanks for all of your help. Scott
Scoteg
08-10-2018, 10:57 AM
1974 Argosy 26
Morrill
, Nebraska
Does it open straight up or is it hinged?
08-10-2018, 02:22 PM
1965 22' Safari
Boulder Creek
The vent opened straight up with the twist openers.
Scoteg
08-10-2018, 03:29 PM
1965 26' Overlander
Tulsa
, Oklahoma
Vintage trailer supply has them
08-10-2018, 03:46 PM
1967 26' Overlander
Alpine
Is it rectangular or square ?
08-10-2018, 07:39 PM
1965 22' Safari
Boulder Creek
The vent is square about 14"X14"
vintage trailer supply sells a replacement lid with hinge top, could work, maybe I could modify?
I would prefer the original hardware if possible.
thanks for the input!
scott
Scoteg
08-11-2018, 06:54 AM
1967 26' Overlander
Alpine
I think that’s what they replaced mine with . They pop riveted the lid to the risers . The reason I ask is I’m replacing mine ,the whole thing in the next few weeks .
08-11-2018, 07:25 AM
1978 25' Tradewind
1954 15' Byam Holiday
Linden
, Michigan
Herr Vent
PM me if your still interested, I may have one in the attic. I believe it is the whole unit.
Regards,
StevieB
08-11-2018, 09:28 AM
Jeff I
2007 25' Safari FB SE
1964 22' Safari
Hammondsport
, New York
lost vent
I found our vent on our 64 Safari opened itself in front when going down the road, once when it was pouring rain. I wired the front twist opener closed so it only opens from the rear position.
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville
, Tennessee
astrodome or 14" x 14" ?
08-11-2018, 10:06 AM
1965 22' Safari
Boulder Creek
Hey guys,
the. vent is 14"X14' square
J Ingersoll that is exactly what happened to us.
I noticed that the vent was open on the front during a gas stop. I shut it, and was planning on inspecting it when we stopped for the night. I guess that goes to show. take the time right away to secure anything that might just fall off on the ride. I learned my lesson. probably.
Scott
Scoteg
08-12-2018, 10:22 AM
1992 21' Sovereign
Tucson
Vent cover
Scott. I have an original vent cover that came from my 68 Caraval which I could part with if tryouts are interested in originality.
08-12-2018, 11:13 AM
1965 24' Tradewind
almena
, Wisconsin
Roof Vent
If the screw risers are still there you are lucky as they are about $90 each!!! Ok, This also happened to me so what I did was - First thing, go to any RV dealer and buy a 14x14 vent cover. It is a standard one for most RVs. About $15. Next Go to a Home Depot or similar store and buy a piece of white acrylic at least 14x14 and about 1/8 in. thick. Thicker if they have it. The smallest piece I found was about 18x24. About another $15. Ok, next. Mine departed from where the “hinge” connected to the top center piece of the riser so one hinge was gone but I had the other one for the pattern to find and fabricate one. It is a small furniture hinge about 3 in. wide and the long part is about another 3 in. long. Buy at least 6 of these as you will have to trim and drill it to get everything in the right place and it may take some trial and error. I think $3.50 for a pack of two. Pick up a tube of clear RTV. Now mine has a similar but longer vent to see how was everything should be. You will have to drill out anything attached to the new vent cover. Then cut and trim the white acrylic to fit into the first step of the vent cover. Then....here is where gets tricky - put the acrylic in place on top of the trailer as straight an even as possible. Maybe set something heavy on top to hold it in place. Next get the risers lined up straight so you can trim the hinges. As for attaching the hinge to the riser I ground off the very top of the riser to make it all flat then drilled a small hole about 1/2 in. deep in the center post of the riser then drilled a hole in the hinge in the appropriate spot. Then used a stainless steel sheet metal screw to connect the hinge to the riser. I did mine so I could drill through both the acrylic and vent cover for attaching the hinges for more strength. Use the RTV to attach the piece of acrylic to the cover. If you have a similar vent on your trailer to use for reference you should be in good shape to make another one. I did it this way to retain more original stuff on the trailer. You could also just buy a complete vent kit from that RV dealer and install it if you are not concerned with keeping original. Good Luck!!!
08-13-2018, 02:32 PM
1965 22' Safari
Boulder Creek
Hey mykytiukr,
Thanks for the detailed response. This could be the rout that I choose to go with. Unfortunately my lid flew off with the lifters, but at least they make an expensive replacement.
Scott
Scoteg
06-28-2021, 03:37 PM
1965 22' Safari
Coalmont
My screw up riser just broke on '65 22' safari. 90$ seem like a lot but where could I fine one?
06-28-2021, 05:41 PM
1965 26' Overlander
Tulsa
, Oklahoma
I think I have at least one of the lifters for a 65, PM me for price.
