03-27-2021, 11:49 AM
Bend
, Oregon
Longer stabilizer jacks needed
Hello, I installed a lift kit on my 22FB Sport. Are there longer stabilizer jacks available? The original jacks have a 19” arm. Hoping there are 23-25” jacks that will fit the same bolt pattern (two bolts 3” apart and a third bolt 16” OC from those. I found 25” jacks online but with different bolt pattern.
This would allow me to get rid of a set of leveling blocks I’ve been using and free up some valuable tool storage space
Thank you,
Geza
03-27-2021, 11:59 AM
2015 20' Flying Cloud
Kingsport
, Tennessee
I'll admit, for my stabilizers, I just made up some blocks (got a 2x10, cut it into squares, then glued into pairs). But, I have a rear bumper to store them in.... yeah, if I didn't have the bumper storage, that'd be a pain to try to find a place to store them. I'm interested in seeing if there are any others out there suitable....
-Leslie
WBCCI #1051
03-27-2021, 12:04 PM
1964 17' Bambi II
1961 24' Tradewind
Strasburg
, Pennsylvania
Thank you,
Geza
I don't know if you will find similar BAL jacks with a longer arm, but if you decide to go with something else, I would be interested in buying your old ones for my old TradeWind. Are they manual?
03-27-2021, 02:34 PM
2019 19' Flying Cloud
2006 16' International CCD
Front Range
, CO
After I installed my lift kit I installed snap pads. They took up the slack. Expensive, but now that I have them I really like them. Tongue jack pad, too!
03-27-2021, 02:49 PM
Kingsport
, Tennessee
Ooo! I like those. I might still keep the ones I made, but it'd be great to have those. Appreciate the suggestion!
-Leslie
WBCCI #1051
03-27-2021, 03:04 PM
Kingsport
, Tennessee
Ah... drat. I mean, they're nice, but... looking at them, they only add one inch, as opposed to the needed 3". I mean, they'd help, but, would still need to use something in addition to....
-Leslie
WBCCI #1051
03-27-2021, 05:19 PM
Bend
, Oregon
Thanks for the replies all, I’ll keep looking, 25” arm would still remain totally underneath. Pa Bambi, I’ll keep you in mind should I remove the manual stock ones.
Geza
03-28-2021, 09:29 AM
2014 27' Flying Cloud
Stowe
, Vermont
If I want longer stabilizers for my 27' FC, I just use my "lego" blocks under the "short" stabilizers.
03-28-2021, 09:41 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We also use a stack of lego blocks when the terrain causes a stabilizer jack to come up short.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-28-2021, 09:58 AM
1975 31' Sovereign
North Fort Myers
03-29-2021, 10:11 AM
Bend
, Oregon
Thank you, I need 4 independent jacks; often camping on uneven ground and currently using the lego blocks. One of those small mods to save a couple minutes setup/takedown each time as well as free up storage space
06-22-2021, 12:25 PM
F150 4X4 ProPride
2015 30' Flying Cloud
TOMBALL
BAL Stabilizer Jacks are Airstream OEM
https://balrvproducts.com/index.shtml
Airstreams have "C" Jacks available in 19,22,25, 28 and 31 inches
06-23-2021, 05:25 AM
2004 30' Classic
California
, MD
I installed BAL Power C Jacks.
They have a 25 inch leg height.
2004 30' Airstream Classic
