Old 03-29-2020, 07:51 AM   #1
2019 28' Flying Cloud
Dripping Springs , Texas
Let's make some Mud Flaps!
Had a lot of mud & rocks splattered across the dump valves after our last trip, it's time to add the feature that Airstream left out: Mud Flaps
Costco had "Dewalt" branded flaps, $40/pair. Rather spendy IMO but they are very robust and high quality.
HD shopping list:
- 3-ft section of 1x1" aluminum bar
- Ten stainless machine bolts, 1" length, 0.25" diameter
- Matching nuts & washers
- Two packs of #12 hex head galvanized sheet metal screws, 0.75" length
Steps:
1. Fit the flap under the wheel well and cut it to size:
- About 3" ground clearance
- Left about 6" within the wheel well
- Removed the rest from the top
- Shaved off the ridges on both sides of the flap, even with my 1x1 bar (flap now butts up against the bar)
- Cut a little slot to accommodate the bottom edge of the trailer
2. Fit the bar and cut it to size:
- Mounting point will be the aluminum strip at the back of the wheel well. I left it completely in place, including the rivets
- Flap is offset a couple inches from the interior wall
- Outer edge of flap is even with the edge of the trailer and also the outer edge of the wheel
- Left end of the bar is even with the mud flap. IMO this is most stable.
3. Mount bar to flap:
- Drilled 5 holes into the bar, then the flap, 0.25" size
- Added my SS hardware, used red threadlock. It's not coming apart.
4. Mount bar to trailer:
- Marked spots on bar where it would mate with the AS aluminum strip
- Drilled 0.25" holes in the mud flap bar
- Marked spots on AS aluminum strip
- Pre-drilled with bit slightly smaller than my sheet metal screws
- Added "Goop" to each hole
- Drove in the sheet metal screws. Very secure.
- Note: I also ground little depressions into my bar where the rivets are located in the Airstream aluminum strip
5. Attach the interior 6" flap:
- Pre-drilled with bit slightly smaller than the sheet metal screws supplied with the Dewalt flaps
- Drove in the supplied hardware, 4 per side
- Now the flaps are not going anywhere, ever
Kalashnikov is offline   Reply With Quote
Old 03-29-2020, 08:07 AM   #2
turk123's Avatar
2019 30' Classic
Canfield , Ohio
What a great idea and very resourceful. I had to replace a cap over our last trip due to rock damage.
Great project for these times at home.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 03-29-2020, 09:03 AM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Very good work!
Mud flaps on a AS? AirHog Rock Guards, Segment & Window Protectors 8 04-29-2005 12:42 PM
Mud flaps on a AS? AirHog 2000 - 2004 Safari 0 04-05-2004 08:07 PM
Roadwing removable mud flaps Kistler Our Community 4 03-20-2003 05:39 AM
Mud flaps on an A/S Silvertwinkie Our Community 8 03-10-2003 07:29 AM
Mud flaps on an A/S MH ALANSD Airstream Motorhome Forums 3 03-10-2003 06:58 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
