07-23-2020, 07:41 AM
2019 30' Flying Cloud
Liverpool
, New York
Leaks
We have 2 problems with our 2019 30' Flying Cloud which we bought used from a dealer 3 weeks ago.
1: the toilet leaked a lot when we first filled it with water to put in the tank tablet thing. The water flowed across the bathroom floor. It then leaked after every flush. The dealer came 5 hours to pick it up and had it for two weeks but couldn't find a leak. We finally went back to pick it up. We couldn't get it to leak more than a few drops which they said is condensation.
2: When we just drove it home (a 3 hr trip). When we opened the door there was water covering the entire coach floor. It was also on the couch and all over the kitchen counter. We think the kitchen sink Faucet leaked when we drove. The first hour of our trip we didn't have the sway bars tight enough so the trailer swayed a bit but why would the faucet leak?
Has anyone had these problems?
07-23-2020, 07:45 AM
Tampa
Do you turn the pump off while you're not using it?
07-23-2020, 07:54 AM
Liverpool
, New York
Oh man we are so new at this. We don't know. So no. We'll have to find out how to do that. So that explains the kitchen faucet. Does it explain the toilet leak?
07-23-2020, 08:38 AM
2018 30' Classic
Thousand Oaks
We turn the pump off when driving as well as a hair tie around the bathroom and kitchen handles to prevent them from wiggling open.
Don’t know about your toilet. Shouldn’t leak unless it’s cracked unless the seal at the floor is bad or the pex his busted somewhere?
Have you looked at all the connections behind the toilet?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
07-23-2020, 09:11 AM
Liverpool
, New York
Leaks
I just checked and the pump was off. So why would we get so much water? It looked like an entire 16 oz glass of water or more was poured all over.
07-23-2020, 09:21 AM
2002 25' Safari
Dewey
How much water was in the toilet bowl when you started your tow and how much was left when you arrived? We travel with an inch of water or less when traveling as it can splash out.
Richard
2015 25' FB International
my
, house
Did you have water in the bowl? When we forget to empty the bowl before travel, we sometimes have water on the floor from sloshing out.. I know that may seem unlikely, but it will happen on some trips, if the ride is less than perfect.
07-23-2020, 09:26 AM
2018 30' Classic
Thousand Oaks
RE water on the counters and floor, easily could have just been water in the lines. You can open the valve with the pump off to drain the lines prior to closing and securing prior to travel
BigSxyWhtGuy
07-25-2020, 05:06 PM
Liverpool
, New York
Thanks for the great advise! Where is that water valve?
07-25-2020, 08:15 PM
2018 30' Classic
Thousand Oaks
Just turn the faucet on with the pump off. We catch that water for AM coffee
BigSxyWhtGuy
08-12-2021, 06:20 PM
Liverpool
, New York
Update on leaking toilet
After 10 months at the dealer we finally have a new toilet. We stayed in it last night and no leaks! The RV even smells better!!!!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Leaks, leaks, and more leaks
da_lizard |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
15 |
04-11-2016 11:36 AM |
LEAKS LEAKS more LEAKS in ATL
parzam21 |
General Repair Forum |
17 |
12-27-2015 02:46 PM |
Leaks, Leaks and more leaks
Jim in Pima |
5 |
12-12-2007 11:23 AM |
Leaks, leaks, leaks
jeffnjen30 |
8 |
08-27-2007 11:03 PM |
leaks leaks leaks
Globie64 |
10 |
12-31-2005 05:49 PM |
