Help! Just picked up the AS and dewinterizing - the valve controlling the water inlet under the right side of the toilet is leaking, where it makes connection with the pedal. There’s a clear plastic part attached to the toilet with 2 screws. I suspect this is the culprit. Should I remove the screws and take it apart to investigate?
