Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-22-2019, 07:34 PM   #1
1970 27' Overlander
Lakeland , Florida
leak solution?
Given that no matter what you do, leaks are inevitable and when they occur the water will drain down the inner skins down the the C-channel, why not drill drain holes through the channel and sub-floor so the water drains into the belly pan?
I'm sure there are a multitude of reasons why this is a bad idea, just thought I would ask. Seems like a simple solution.
CraigCam is offline   Reply With Quote
Old 04-22-2019, 07:55 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I asked this same question years ago. Don't recall getting a reasonable answer.
Why the belly pan is not vented is another question.
Old 04-22-2019, 08:02 PM   #3
dznf0g's Avatar
Oswego , Illinois
I vented mine several years ago. Click image for larger version
-Rich-
Old 04-23-2019, 07:31 AM   #4
1963 28' Ambassador
Northern VT , Vermont
Did both on our '64. Probably will never know if it makes a differance. Used 6" X 12" alum louvered panels in centerline of belly pan, one forward & one aft, backed with kevlar screen for bugs. For the "drain holes" between skins was concerned about exposing the plywood IF the water did drain making matters worse. Epoxied in plastic tubes to line the holes. Only did both sides of the door and below the major windows. Fact is I doubt I'll live long enough to know if it mattered !
putback is offline   Reply With Quote
That darned leak!! Need help from leak experts !! nickclifford General Repair Forum 20 12-03-2015 05:52 PM
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
