01-21-2022, 06:07 PM
2015 27' Flying Cloud
Williamsburg
, Virginia
Leak near fresh water tank
We are full time and have a 2015 27 ft Flying Cloud. We recently went back on the road after the holidays and I found that there seems to be a leak somewhere next to the fresh water tank. We are using it bc of cold temperatures right now. Please see pictures of the leak. It is not intruding into the living space at all but I do find a drip outside inside the wheel wells plug in side where the tank is. I don’t see any pipes leaking that I see from the inside as well.
Would anyone know what this could be from?
Thank you for your help and thoughts in advance.
01-21-2022, 06:53 PM
2019 30' International
Pennsylvania
, Pennsylvania
Check your freshwater inlet valve. Inside. Possible leak between skins. See if you can reach it from inside, feel the insulation, see if it's wet, or if you can see water drips on it from inside the trailer.
And/or take the screws out from outside and see if you can pull it out far enough to see if it's leaking.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
01-21-2022, 06:58 PM
Williamsburg
, Virginia
Okay thank you for the suggestion with check the fresh water inlet from the inside. Will def try and see if I can reach and feel around. Thank you!
01-21-2022, 07:04 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Also look at the water tank drain hose. Pretty sure It uses hose clamps on barbed fittings. It’s not under pressure just a tank drain hose. Possible access panel under pan at tank drain valve.
01-21-2022, 07:09 PM
Williamsburg
, Virginia
I just took a hard look again and noticed that the normal water inlet insulation between the skins was wet. Not so much the fresh water tank inlet from what I could see. So that may be the reason.
01-21-2022, 07:16 PM
Williamsburg
, Virginia
Thanks will also take a look at the drain hose.
01-22-2022, 11:52 AM
2014 27' FB International
Hooper
, Utah
I have had the spin welds going in to and out of the fresh water tank leak. If you have water in the fresh water tank and the water level is going down without using the water...but water dripping from the area of the connections, you might have a crack in the weld. The only way to fix it is to drop the tank and replace the fitting with another spin weld fitting. Costly......it cost me $975. When you travel down the highway and the water in the tank moves back and forth the pressure can create the leak in the fitting. Good luck.
01-22-2022, 12:17 PM
2013 28' Flying Cloud
Penn Yan
, New York
Leak
This an increasingly common problem. When the hot water tank heats the water, the water in the system expands enough to push water pass the seals in the regulator.
Easy fix. Order from an Airstream dealer and add getting the gasket kit because the gasket/seal doesn’t come with the new valve.
I suggest while you are waiting for parts, pull the regulator out of the wall cavity so the leak is outside.
Get a plastic sandwich bag and tape the top of the bag over the hole in the side of the Airstream to keep out the rain.
01-22-2022, 02:41 PM
Pennsylvania
, Pennsylvania
Yes, I said freshwater, but meant city water inlet. That sounds like it may be the issue here.
01-22-2022, 04:44 PM
Williamsburg
, Virginia
Yeah but it’s weird bc we weren’t hooked up to city water at the time. I noticed it before but thought it was just condensation. Can it still drip from city inlet without it being hooked up? Thanks again everyone!
01-22-2022, 06:26 PM
Pennsylvania
, Pennsylvania
Yes, it can still leak without being hooked up to city water. The plumbing system is under pressure even when just using the on board pump and water. This causes the leak at the water pressure valve just the same.
02-02-2022, 10:02 AM
2019 27' Flying Cloud
Kansas City
, Missouri
Following...good info
Piggy Bank
02-02-2022, 12:06 PM
2013 20' Flying Cloud
2014 16' Sport
Dunedin
Most likely the water inlet valve leaks. Easy fix. Just unscrew the outside four screws , pull it off, hang onto the hose on the inside, unscrew it put a new inlet valve in screw it all back together. I did it. Understand it happens every couple years. Plastic is brittle
02-02-2022, 06:54 PM
2022 25' Flying Cloud
Ocala
Us, too.
We’re having the same issue. We already felt under the kitchen sink and it is wet along one of the pvc pipes. Hard to actually see. We will have to remove the 2 drawers in front of the pipe and can’t figure out how to do that!
Any suggestions?
02-02-2022, 06:55 PM
Ocala
For now we have filled our freshwater tank and disconnected city water. Hope to see no leak outside in the a.m. if we do it must be something else.
02-03-2022, 03:32 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
If your city inlet is the culprit, you might still have a leak when using the fresh tank instead. The pump keeps the system pressurized and therefore there is water forced up into the city water valve.
02-03-2022, 06:44 PM
Penn Yan
, New York
Water leak
The problem you are having stems from the hot water heater. When you heat cold water it expands. The closed system has nowhere for the pressure to go and blows out through the city water regulator.
To help alleviate this, when you turn on the hot water heater, every so often open a faucet to release the pressure.
The way I fixed it was to install a accumulator in the system. The accumulator can be placed anywhere on the pressure side of the pump.
When the water expands the accumulator takes the increased pressure hopefully saving the regulator.
Remove the 4 screws holding the city water inlet and pull the regulator out of the trailer.
I would leave the regulator outside u til you can replace it. Take a small plastic bag and cover the top of the hole in the side of the trailer leaving the bottom open so the insulation can dry.
I would order the regulator and gasket kit from an Airstream dealer so that you get both the regulator and gasket. The gasket will not come with a new regulator.
Easy fix.
