Leak at Door
Our 2008, 31 ft Classic has had a leak at our entrance door for a few years. Not even sure when we first noticed it. Initially, we found moisture under the welcome mat but no obvious sign of a leak. Never really got any worse. This winter went to check on the trailer in storage and found snow blown at the bottom of the door. Now it’s really serious!
The door gasket was replaced August 2018 but does show some wear. Have tried shaping the door for tighter fit (via the 2x4 in the door method). When the door is closed, the top of door has some “give” when pushed. It also appears that the door gasket is below the surface it should mate with on the top.
Some of the caulking above the door needs to be replaced after this winter season.
Don’t know if the this may be related but over the last 3 years there’s been an annual “separation” between the closet/attachments and the door side wall (curb side) of the trailer. (photos below) The first is the partition next to the stove. Second photo is between the closet and the bedroom wall. We don’t see any issues with partitions on the street side. We don’t have this problem anywhere else. The curbside bedroom storage and all along drivers side do not have any issues.
Visually the exterior skin looks straight. When shaping the door both the top and bottom needed to bend which makes me wonder if the curb inside wall is distorted.
Questions:
1. Has anyone had this experience with your door and how was it solved?
2. Has anyone had experience with the gaping between the interior wall and the partitions (closet), upper cabinets). If so, what was the cause?
3. Is there a connection between the door leaks and the gaps?
Thanks in advance for your experience and advice.
Photos will be provided when I figure out how to do that
