Leak: Above Rear Window 2015 27FB
If you want to find a leak, visit the PNW...
After spending the past year in very dry climates, we have discovered a slow leak that appears above the middle rear window of our 2015 27FB during heavy rain. Water seems to be making its way between the interior and exterior skins, then appears along the upper edge of the screen. I'm pointing to the spot where the water appears, although there's no leaking in the photos.
I got up on the roof to inspect the seals and rivets. Everything looks good there. The only points of ingress that I see are 1) around the radio antenna, and 2) around the clearance lights.
Around the leading edge of the lights, there is a gap between the aluminum and what looks like a foam seal. I'm not sure what the actual roof penetration looks like, but I did put some silicone sealer (all I have on hand) around the most obvious gap you can see in the photo.
I'm still seeing the leak, but it seems like heavier and more sustained rainfall is required for the leak to start, so I'm wondering if sealing around the lights is the right direction.
Has anyone else had a leak that appears where I'm seeing ours? Should I seal around the entire base of the clearance lights, and also where the plastic housing meets the chrome trim? Any other ingress points I should inspect?
Thanks in advance!
