Old 12-26-2016, 08:46 AM   #1
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Late model AS roof patch?
I have a 2017 FC and I need to remove a zamp solar preinstall box from the roof (6x8 inches, 3 inches tall).
I am not sure of the size hole in the roof, if small enough I can use Sikka. If a patch is required I had a few questions and was hoping others could help:
1. Can you purchase the white coated aluminum for repairs? If so, please provide vendor or link
2. If a patch is needed, what thickness of alclad would be desired .032 or .04?
3. If a 6x8 inch patch is needed, could I use VHB tape, with Sitka over it to hold down, as I want to avoid holes in roof.
Thanks for any help, suggestions or advice.
Thx
Troutboy, aka Rich
Troutboy
Troutboy is offline   Reply With Quote
Old 12-30-2016, 09:55 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
The reason to use metal patches to cover holes is to provide a redundant barrier. You would have a sealant and a new layer of metal to provide the second layer. The repair would last a very long time.
Patches that I have made were .040. I crowned them so that water would run off. Normally I would lay the patch on the place I needed it and see what curve to make. I have an English Wheel so I could quickly make a compound curve to fit. Some folks use a bag of sand and a soft mallet to create the curve part.
I like using round patches and rivets, then a nice layer of Sikaflex that would ooze out; also I coat the rivets as they go in.
My guess is that the hole is around 3/4" in diameter, but that is just a guess. A 3" diameter would work good for that size.
As to white metal or paint, you can purchase white aluminum flashing or related parts from a box store, it will be thin and soft. I would use better metal and use white spray paint, white is very forgiving.
sgschwend is offline   Reply With Quote
Major Model Year Changes to Late Model Flying Clouds Mark Pratt 2009-2015 Flying Cloud 12 03-23-2015 05:27 AM
To patch or not to patch... truckirwin Repairing/Replacing Floor &/or Frame 8 05-01-2014 05:18 AM
Body mods: To patch, or not to patch? Belegedhel Ribs, Skins & Rivets 0 01-05-2012 09:33 AM
Roof re-enforcement/ patch GnJ Roof Vents, Skylights & Fans 2 05-04-2010 08:00 AM
