Old 07-02-2022, 12:09 PM   #1
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Keeping the medecine cabinet door open
There have been threads and posts from frustrated airstreamers wanting a solution to keeping their medicine cabinet door open (for those models where there is still a medecine cabinet).
The most common solution, the one I used, is the "door piston" that compresses when you close the door and expands to open the door when unlatched.
After a few years of use I noticed that when you close the door you are leveraging pressure on the door hinges, which after a while, will pull out the hinge screws.
The alternative is a mechanism which does not exert pressure as a piston does but simply stabilizes the door in place through adjustable friction.
In the pictures you can see that I installed one on each side of the cabinet; and in the center of the "arm" you can adjust the friction which a regular hex key/Allen wrench. You can find these on Amazon. They are a little tricky to install, which means getting the position just right for the max opening angle you want (probably 110 degrees); I recommend trying it out on two pieces of plywood to avoid extra holes in your cabinet.
ID:	418803   Click image for larger version
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
Hermes is offline   Reply With Quote
Old 07-02-2022, 03:26 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Original hinge has adjustable tension hidden on arm
Hermes, that looks like a nice solution.
I considered alternatives until I found this post and the original arm has a spring tension adjustment somewhat hidden.
After tightening up the spring, the mirror now stays up at the ceiling without any additional effort.
ID:	418814   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 07-02-2022, 06:26 PM   #3
Hermes's Avatar
On my unit (a 2016 International) the medicine cabinet hinge has no spring mechanism, it's just a straightforward hinge so you needed to hold the door open with one arm and use the other hand to access things.
Old 07-03-2022, 07:08 AM   #4
jeffmc306's Avatar
McHenry , Illinois
Ah, that explains it! Your solution is perfect.
I wonder what year they made the change? It’s funny because after Airstream made the change owners complained about the same issue because AS never adjusted the spring tension out of the box and the doors would hang half open. Once you tightened the screw the door was fine.
2018 FC23FB
WBCCI# 10258
RETIRED!
Article about keeping campgrounds open SnooMc On The Road... 1 03-17-2020 05:24 PM
Medicine cabinet door won’t stay open Hermes Cabinets, Counter Tops & Furnishings 20 08-20-2019 02:17 AM
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
Keeping old school door and drawers in place Tony S General Repair Forum 13 04-03-2014 06:21 PM
Doohickey for keeping door closed Stefrobrts Doors & Locks 50 09-08-2010 04:16 PM
