Sorry to hear you’re having trouble. What was the outside temperature? I ask because heat pumps don’t really work when it’s under 45 degrees Fahrenheit. I’m wondering if the clicking was your furnace trying to light. Was your propane tank open, giving the furnace gas to light? If not, then perhaps your system tried to light the furnace, and then switched to heat pump when the furnace wouldn’t light. Then perhaps it was too cold for the heat pump, so it went back to trying the furnace and continued to cycle.
That was a wild guess on my part, but it’s what pops into my head based on your description.
I would verify that your propane tank is open, and then burp the lines to remove any air by lighting a burner on the stovetop. Once you’ve done that, I’d try turning the furnace on and verifying that it lights and it’s working. Once you have that done, I’d try the auto setting again and see what happens.
Good luck and let us know what you find as you troubleshoot it.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Sierra Denali 1500
Airstream Club International #2805
