RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-27-2020, 12:35 PM   #1
2004 22' Safari
Albuquerque , New Mexico
Is there any way other than...
I have a bolt head (?) coming up from the floor and it is tearing the floor cover.
At first blush I thought it was probably a bolt that needed tightening and looked under the trailer only to find I had to drill out a bunch of rivets in the bottom of my 22 foot 2004 Safari to even look and see if there was a nut on the bottom to tighten. from the placement, I figured it was probably a bolt that held the floor to the frame, but since I can't see it I don't know what the easiest fix is.
Anybody know what is happening here and if there is an easy way to fix this?
I uploaded a picture of this...
Silver.Sanctuary is offline   Reply With Quote
Old 11-27-2020, 01:36 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
On my unit there are no floor bolts, merely large self tapping screws that hold the plywood down. I would suggest using an Exacto blade to finish cutting the semicircle a little further around the head so you can access the top. The screw uses a large Phillips head on my unit which I suspect is the same on your unit. You can glue the floor covering back down on top of the screw head once retightened. You should acquire some scratch repair crayons to fill the small crack around the screw head and camouflage the repair spot.
https://www.walmart.com/ip/Furniture...Cove/827143260
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Are there any other 1982 Limiteds out there? GStephens 1982-1983 Limited 11 04-23-2009 09:13 AM
Are their any other 1967 Ambassadors out there??? till 1966 - 1969 Ambassador 9 03-21-2008 11:14 AM
Any other '02 Bambi LS units out there? dtbw 1997 - 2004 Bambi 9 09-27-2004 01:04 PM
Why is Airstream any better than the other brands? Narnian Our Community 54 08-08-2003 04:13 PM
Any other's 26' other than 60's Overlander? 59toaster Our Community 4 03-21-2003 11:00 AM
