Inverter/converter Problems
I have a ‘94 Classic 36’ Airstream with a diesel pusher. Last evening after arriving at our boondocking spot all of the lights went out. When I fired up the generator the outlets wouldn’t work? So I started the motor and all the lights went back on (and fridge, etc). But turning the motor off caused everything to shut down again.
This morning was the same…until all of the sudden the lights went on again; I fired up the generator and the outlets worked…everything good and back to normal; for about 6-8 minutes. Then, everything back off.
We’re 700 miles from home and will get it looked at when we return; but just wondering in the meantime if anyone had any ideas or suggestions?
Thank you.
Danny
