Old 07-19-2019, 09:39 PM   #1
2018 27' Flying Cloud
The Villages, FL , Florida
Inverter 2018 FC 27FBQ
I have a recurring problem. Intermittently, the inverter AC bypass shuts down. No lights on the display. No power at the inverter outlets. Microwave also shuts down. The current work around is to plug the inverter into an alternate outlet. As a precaution I unplugged the microwave and am using an alternate outlet. Power to the inverter outlet is intermittent and when non-functional, the convection microwave outlet is also non-functional. Why would the factory wire an appliance that requires 1500 running watts to the inverter that supplies 1000 watts. The problem is not directly linked to the operation of the microwave. Did the factory run a hot from the inverter to the decidcated microwave circuit? Airstream located the inverter in a location that it is impossible to read the display. I am thinking the inverter outlet maybe bad or have a bad connection.
Sitesee is offline   Reply With Quote
Inverter help 2018 FC 27FBQ Sitesee Electrical - Systems, Generators, Batteries & Solar 1 07-22-2019 07:10 PM
Rear hatch 27FBQ Renascence 2016 - Current Flying Cloud 1 07-17-2019 03:56 PM
Question? Replacing factory converter & inverter with 2k watt inverter charger cptdzl Batteries, Univolts, Converters & Inverters 1 06-23-2019 07:55 AM
prep for my solar future: Inverter charger/inverter-converter combo wonderlust87 Electrical - Systems, Generators, Batteries & Solar 1 09-13-2017 10:50 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
