Intermittent loss of communication between Firefly Multiplex Control Panel and Alde
Seeking advice, ideas, recommendations on a problem.
We on the road heading to Tampa and just started experiencing the problem earlier this morning after having run the hydronic heating all night.
The problem relates to the loss of communication between the Firefly Multiplex Control Panel and the Alde System in our 2018 Classic M30 (albeit the problem is intermittent and not continuous) ??? Puzzling ???
When it happens, the most noticeable effect is the loss of temperature readings on the Firefly Panel and further-to-which seems to be affects other control features on the Firefly Panel, i.e. water pump on/off (not working), HVAC functionality (unable to turn on/off), etc.
As I mentioned, the problem is not constant and is more intermittent, i.e. one minute all is working fine, no issues....then 20, 30 maybe 60 minutes later it fails, i.e. whereby where we would normally see ambient and set temperatures for the cooling or heating there are nothing but ---dashes--- and a message stating "loss of communication in yellow below". When this occurs, from the point on we have no control of the system functions controlled by the Firefly panel....then, oddly 10-15-20 minutes later (without touching anything) everything seems to be working again as if the communication has been restored until it does it again.
FWIW, This problem began this morning after having been parked overnight, connected to 50-amp shore power and running the hydronic heating.
Checked the Alde panel under the sink cabinet it appears to be good, including the lightening bolt indicating power is on. Checked panels beneath the wardrobe, no tripped breakers or buses.
Contacted AS Customer Service/Technical Support and they stated it sounds like the Firefly Panel is going bad or there could be a connection shorting out. Suggest we get it into a AS Dealer to have the system checked and repaired (Good Luck with getting that done in a timely manner).
Yet to call Firefly but will try to reach them tomorrow while on the road/driving and see what they think.
Meanwhile, Asking for ideas, recommendations from others here in the forum who may have experienced a similar issue.
"Finding the Roads that Await Us!"
Rick & Lydia Williams
