Old 12-01-2020, 07:01 PM   #1
2018 30' Classic
Lake Charles , SW Louisiana
Intermittent loss of communication between Firefly Multiplex Control Panel and Alde
Seeking advice, ideas, recommendations on a problem.
We on the road heading to Tampa and just started experiencing the problem earlier this morning after having run the hydronic heating all night.
The problem relates to the loss of communication between the Firefly Multiplex Control Panel and the Alde System in our 2018 Classic M30 (albeit the problem is intermittent and not continuous) ??? Puzzling ???
When it happens, the most noticeable effect is the loss of temperature readings on the Firefly Panel and further-to-which seems to be affects other control features on the Firefly Panel, i.e. water pump on/off (not working), HVAC functionality (unable to turn on/off), etc.
As I mentioned, the problem is not constant and is more intermittent, i.e. one minute all is working fine, no issues....then 20, 30 maybe 60 minutes later it fails, i.e. whereby where we would normally see ambient and set temperatures for the cooling or heating there are nothing but ---dashes--- and a message stating "loss of communication in yellow below". When this occurs, from the point on we have no control of the system functions controlled by the Firefly panel....then, oddly 10-15-20 minutes later (without touching anything) everything seems to be working again as if the communication has been restored until it does it again.
FWIW, This problem began this morning after having been parked overnight, connected to 50-amp shore power and running the hydronic heating.
Checked the Alde panel under the sink cabinet it appears to be good, including the lightening bolt indicating power is on. Checked panels beneath the wardrobe, no tripped breakers or buses.
Contacted AS Customer Service/Technical Support and they stated it sounds like the Firefly Panel is going bad or there could be a connection shorting out. Suggest we get it into a AS Dealer to have the system checked and repaired (Good Luck with getting that done in a timely manner).
Yet to call Firefly but will try to reach them tomorrow while on the road/driving and see what they think.
Meanwhile, Asking for ideas, recommendations from others here in the forum who may have experienced a similar issue.
"Finding the Roads that Await Us!"
Rick & Lydia Williams
rewillia is offline   Reply With Quote
Old 12-01-2020, 09:46 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Is your fire fly up update? V3.8 is what I have
Sounds to me like it may actually be your main panel on the alde going out. When it’s not communicating to the firefly, is your panel under the sink off?
My experience with the alde main panel going out is intermittent working as well. My alde control panel under the sink would go blank though. Truma/Alde helped me diagnose the panel issue as well as installation support over the phone.
If it is the main alde panel, it’s a pretty straight forward plug and play correction. Keep us posted. Would love to hear what the solution is!
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 12-03-2020, 03:32 PM   #3
2018 30' Classic
PROBLEM SOLVED with the stellar customer service and technical support of Firefly, imc, particularly Neal G.
The problem of intermittent loss of signal to the G6A DC panel was a loose OR possibly just dust making for poor connections to the 7100053 PMM which is actually located underneath the dining booth bottom cushion next to the wall (not where Airstreams diagram shows it to be under the dining table).
Name:	PMM 7100053 CAN.jpg
All Good!
Old 12-04-2020, 03:22 AM   #4
2018 30' Classic
Another view, PMM 7100053
Name:	FIREFLY LOSS OF COMMUNICATION WITH PMM 7100053.jpg
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 64 08-15-2021 06:36 AM
Multiplex Control Panel + Blue Sea 7622 ScottP Sprinter and B-van Forum 6 11-02-2019 11:54 AM
Questions about Firefly and Multiplex Interface Re-Pete Electronics & Connectivity 0 11-24-2018 09:31 PM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
Camping Tomorrow and Fridge flashes E0 Communication Fault SilverCottage Refrigerators 7 09-27-2007 09:31 AM
