interior fixes
After 7000 miles on our AS 25 RBT, there are some things I want to fix:
1. The twin mattresses hang over the base by 3". As a result, if you roll over near the edge, it feels like you will be pitched to the floor. Reading the Forum, this is a common issue with many (especially us older and heavier dudes that thrash around). I am going to extend the base out about 3" and add a lip to hold the mattress from sliding off. Maybe add it to the bottom as well. Having spent a fair amount of time on sail boats that have bunks with a retaining lip, this may work on my land yacht.
2. European hinges pop off all the time. Everytime we open the lower bins, the hinges come off. I am going to either lock the hinges, or replace them with hinges that do not come apart. I do not need an easy release on the bins. The front uses standard hinges, and the rear users Euro hinges. Because of the door size and operation, it will not work just changing to a standard hinge.
3. Condensation under the mattress during cool weather when the trailer is shut tight at night and condensation forms under the mattress. I am either going to use spacers under an overlay plywood, or just use the extension and put the hard web material under the mattress. For those how have this issue, you know what I mean.
Would like to know what you do about these issues, if anything. I know there are examples on the Forum, but it is spread over the place.
Once I have a final design, I will post.
