07-06-2022, 09:03 AM
Vermont Airstream
2022 16' Caravel
Franklin
, Vermont
Important looking screw found rolling around
Found this gold screw rolling around near the electrical panel (cover was still closed). Looks important...
Seems like the type of screw used to secure the wiring in a breaker - slotted as well as a square driver.
All the cables in the breakers seem to be secure/everything electrical seems to work.
Any ideas of where this might have come from or areas I should look?
Thanks!
Gregg
07-06-2022, 09:09 AM
Oswego
Looks like a negative buss bar lug.
Sent from my SM-G950U using Airstream Forums mobile app
-Rich-
07-06-2022, 09:10 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Look on a buss bar for an open hole, no screw in it. Also look for loose wire that is stripped and has indentation on wire showing it WAS connected.
2007 22' International CCD
Corona
Possibly came out of the neutral or ground bus bar. Probably an extra?
07-06-2022, 10:20 AM
Vermont Airstream
2022 16' Caravel
Franklin
, Vermont
Great suggestions - I bet that's where it came from ~ Neg. bus bar. I'll report back!
Thanks!
07-06-2022, 12:57 PM
Sag Harbor
, New York
Originally Posted by rmkrum
Probably an extra?
Yes likely IMO.
Peter
07-07-2022, 10:06 AM
Falmouth
, Maine
Hinge Screw
Looks like the adjustment screw for a European hinge
07-07-2022, 11:19 AM
1988 32' Excella
Robbinsville
, New Jersey
Might have been an extra that fell out of techs tool bag. People have found loose parts and pieces that weren't cleaned up after assembly, then bounced into view after travel.
07-07-2022, 02:41 PM
2016 28' International
Trois-Rivieres
, Quebec
Yup, I vote for that hypothesis... we are staying tuned !
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
07-07-2022, 02:51 PM
Somewhere
, South Carolina
Buss bar, euro hinge and a ufo part.
Can’t wait for the rest of the story!
All interesting possibles.
07-07-2022, 03:53 PM
2019 30' International
Pennsylvania
, Pennsylvania
Yeah I was all in on the bus bar theory but then the hinge theory came on board and I said WHOA NELLIE! Still waitin' for the answer
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
07-07-2022, 09:13 PM
2019 30' Classic
Belen
, New Mexico
We find things like that all the time. Sometimes I find where they go and sometimes it drives me crazy till I realized that when they assemble these,. If the tech drops a screw, it is often more time efficient to get another than find the one they dropped.
07-08-2022, 05:59 AM
Sag Harbor
, New York
Originally Posted by GCinSC2
. . . a ufo part.
Most likely!
07-08-2022, 06:22 AM
Superannuated Member
2001 19' Bambi
Beaver Lake
, Arkansas
Throw it away, then you will figure out where it was supposed to go.
07-11-2022, 03:56 PM
Airstream - Other
Knoxville
, TN
The finish would lead me to an adjustment screw on a European hinge.
07-13-2022, 10:21 AM
Master of Universe
2008 25' Safari FB SE
Grand Junction
This was the first and only mention of UFO’s. I am willing to accept that as the real cause if you can show the evidence. Do space aliens spread strange screws around? Do they have transmitters to the mother ship? Can they control Airstreams from the dark side of the moon? What info is the “site team” holding back from us?
If I weren’t convinced that UFO’s are the answer, I’d agree it may have been dropped by a worker. He may have seen one was missing and got another screw, dropped it, it rolled underneath something and it was lunch time, then he at his lunch and forgot about the screw. I have seen square drive screws that also can be used by a standard slot screwdriver, but not that many. They may cost slightly more to make, so they aren’t that common. Square and star drive screws aren’t that commonly used because most people don’t have adapters for them, but they, like Philips screws, have become more common with time. If it is from a cabinet hinge adjuster, where is the askew cabinet door? Buss bars sometimes have unused screws, so it may have come from that—never tightened, it easily backed out. You may never find the original place for it.
Could it be our future space alien overlords do these things, like leaving trash anywhere they can hide it in Airstreams, to confuse and weaken us?
Gene
07-13-2022, 12:44 PM
2018 16' Sport
Hurley
, New York
Gremlins
Surprised no one mentioned a stray gremlin as is usually blamed in an aircraft.
07-14-2022, 12:39 AM
2018 23' Flying Cloud
Anchorage
, Alaska
Finding stray parts seems to be a fairly regular occurrence for me. I just keep a bag for stray parts and eventually I I find where they belong or use them somewhere else in the trailer.
