Old 03-03-2021, 05:49 PM   #1
zen_stream's Avatar
1968 28' Ambassador
Portland , Oregon
I think I screwed up
Iíve been putting on a layer of reflex in my trailer. Not a lot of info on how to do this. Lots of general info but no specifics of how to adhere it. So I used Tite Seal window flashing tape to keep it in place. It was the only tape I could find that didnít fall off the aluminum. I guess I didnít do my research because I just found out this is rubberized asphalt tape. It kinda smells like tar if you put your nose up to it.
Now Iím worried this is going to off gas when the trailer gets hot, or at least it might smell like roofing tar. Sounds like a nightmare.
Should I tear all my insulation out and redo with something else to adhere the reflex? Or is rubberized asphalt tape fine to use in this setting?
Just looking out for potential problems down the road. Click image for larger version
zen_stream is offline   Reply With Quote
Old 03-03-2021, 05:51 PM   #2
zen_stream's Avatar
1968 28' Ambassador
Portland , Oregon
Old 03-03-2021, 06:04 PM   #3
1966 22' Safari
Fredericksburg , Texas
I certainly donít know what the off gassing is going to be. I would err on the side of caution. What if you leave it and finish the insides then it start smelling? Can you heat up a piece with a hair drier and see if it smells like tar? Iím sure it was a bunch of work. If you tear it out and start over, you may try 3M 90 spray adhesive. We used that on the 55 to stick the Prodex and it held up great. Good luck and let us know.
Bubba L is offline   Reply With Quote
Old 03-03-2021, 06:17 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Bet Go-rilla tape would work.
Never noticed a smell and it sure does stick good.👍
Old 03-03-2021, 07:30 PM   #5
2010 25' FB Flying Cloud
Davenport , Iowa
We cut the Reflex to fit and use the curtains and or blinds to keep in place. Heve done this way for 10 years . store the Reflex under the cushions/ mattress.
Airtandem is offline   Reply With Quote
Old 03-03-2021, 07:46 PM   #6
van guru
1994 28' Excella
Hood River , Oregon
LowE is much better than Reflectix. It's a closed cell foam with aluminum skins. The bubbles in Reflectix tend to go flat over time. 3M 90 spray adhesive would be a good way to bond it. Or use this tape: https://www.amazon.com/gp/product/B00H1U35XQ
All the best,
Hein
Hein is offline   Reply With Quote
Old 03-03-2021, 08:30 PM   #7
Davenport , Iowa
For removal of the tape; one might try WD40. I had tar from road construction over a good portion of my A$$ and it removed it. I also used Remington gun solvent,
Old 03-04-2021, 05:39 AM   #8
B. Cole's Avatar
1977 31' Sovereign
Rochester , WASHINGTON
Cool
Never noticed a smell and it sure does stick good.��
I agree with Bob.
A big roll of 2 inch Silver Gorilla Tape ( like $9 at Wally World, in paint dept.) should be included with every new Airstream.Sticks to Aluminum+ an added plus,it matches the outside of the trailer .
Would work with this application.
Edit- Upon further review, I see you've got a 1968 model.You might need 2 rolls.
The Gorilla Tape would be be great for sealing the outside window edges, I'm sure the gaskets arnt sealing.
Like sailors say "Any port in a storm"
B. Cole is offline   Reply With Quote
Old 03-04-2021, 08:44 AM   #9
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Sounds like you're installing a reflective layer to the inside of skins... skins cleaned, yep, 3M 90 spray adhesive (follow directions on can). Instead of refltix I used an HVAC 1/4" thick foam with reflective skin on both sides. 4' X 25' rolls on e-bay. Then... many options...I went with another HVAC product 1 1/2" thick fiberglass with 1 side reflective for wrapping duct work. Again 4' x 25' rolls on e-bay. I have also used the thinsulate insulation currently very popular with van builders to make inside window covers ("68 Overlander, lot's of glass), nice product, not sure how cost would shake out. Again glued up with 90 spray adhesive. BTW, window covers are thinsulate spray glued to Reflectix, keep the trailer much warmer when temps drop below 30.
Stay warm (or cool), Mark D
O yeah, no noticeable smell after install but have good ventilation during install.
mrdes8 is offline   Reply With Quote
Old 03-04-2021, 09:33 AM   #10
van guru
1994 28' Excella
Hood River , Oregon
3M citrus base adhesive remover works great on all kinds of sticky residues.
https://www.amazon.com/dp/B00ZGKCF8E
In vans we have found that radiant barriers like LowE and Reflectix are more effective on the inside of the insulation. So the layering is: van (trailer) skin / Thinsulate SM600L / LowE / interior panels.
The reason is that radiant barriers ideally need an air space behind them. Thinsulate SM600L appears to be low density enough to satisfy that need.
The radiant barrier on the inside slows the progression of heat that builds up in the wall cavity in hot conditions and slows heat loss from the interior in cold temps. This strategy has worked quite well in vans.
All the best,
Hein
DIYvan
Old 03-04-2021, 11:04 AM   #11
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Reflectix/Prodex
Air space is crucial.
In our builds, we use scraps of the prodex product ( closed cell instead of air bubbles) to make spacers between aluminum skin and interior for the product to properly function. The R value is similar, maybe a little better than fiber, but without the dust and fibers. We do 3 layers on the roof, with spacers between each layer. Aluminum tape from big home stores works great. ( HVAC Isle) Air tightness is crucial. 2 layers from the windows down...with excellent results. There is still room for the usual wiring over the third layer on the roof. It really helps, also, to run cork or foam strips up and down each interior rib to discourage heat transfer from the structure. This is like arts and crafts! Have fun with it!
BTW, prodex now come in thicker than 1/4 in which will reduce the installation time because you dont need so many layers any more.
Uwe
www.area63productions.com
Old 03-04-2021, 11:16 AM   #12
SailorSam205's Avatar
South East , Michigan
Hmmm. I wonder if the aluminum foil tape used to seal HVAC ducting would work. Designed to adhere to aluminum. I used it to seal most of my S&B ducts (older house). No asphalt and nothing to cause odors. Creates a nice air tight seal.
Al
2017 29' SOB, 2019 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 03-04-2021, 02:20 PM   #13
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
There is an insulation tape used in metal buildings that fastens fiberglas mats to the metal skin. It is placed on the inside with the fiberglas mat against the skin. There is also a repair tape that matches the plastic side of the mat.
guskmg
Old 03-04-2021, 02:59 PM   #14
zen_stream's Avatar
1968 28' Ambassador
Portland , Oregon
Yes, it was a ton of work and in super reluctant to undo all of it. I tried taking down a section today and I'm starting to realize it's going to take me weeks to undo this and clean things up. The tape doesn't come off cleanly and leaves a residue. It rips up the reflectix when I try to remove it. I could probably clean the residue with solvents but I'm worried this will ruin the sealing I've done.
I thought maybe this isn't so bad. So I tried as suggested, taped up one side of a piece of alclad sheet and hit the other side with a heat gun wile in the trailer. Did that for a while. No noticeable petrolium smell other than some trempro I had just put down last night. I'll run the test again and maybe expose the tape to the heat longer. From what I can tell the only time I can smell the tar is when you remove the backing from the tape when applying it, and even then you have to hold your nose up to it.
I looked up the product info and it says noting about dangerous VOCs. States "Under normal conditions of use, this product is not expected to create any unusual emergency hazards." Maybe I'm just overthinking as always. For what it's worth it works really well for holding up the reflectix, its waterproof, won't mold, and seems to keep the air movement under the Reflectix layer to a minimum. Maybe I could do a vapor barrier between he ribs and inner skins just to make sure the potential offending smell.
Old 03-04-2021, 03:07 PM   #15
zen_stream's Avatar
1968 28' Ambassador
Portland , Oregon
Yep I made sure we had an air gap. We have 1/2" foam spacers holding the reflectix layer off the skin. Im going to put rockwol in the remaining 1" of space.
ID:	389892   Click image for larger version
Old 03-04-2021, 04:08 PM   #16
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Uwe,
Is there a particular brand of cork or foam that you use on the ribs?
Thanks!
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
1965 Avion C-10 Truck Camper (65avion.home.blog)
DavidsonOverlander is offline   Reply With Quote
Old 03-05-2021, 12:27 PM   #17
80Ram's Avatar
2017 25' Flying Cloud
Scott City , Missouri
Good luck with your project.
80Ram is offline   Reply With Quote
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 01:39 PM
Oh no....I think I screwed up! Becky B. Waste Systems, Tanks & Totes 7 03-11-2010 11:35 PM
Interior panels screwed in '53? TooMuchTin 1950 - 1958 Cruiser 5 12-13-2005 02:04 AM
screwed and riveted Cruiser Ribs, Skins & Rivets 4 05-14-2003 06:05 PM
