Old 05-22-2022, 01:31 AM   #1
1978 31' Sovereign
Nashvilleville , Tennessee
How to repair this previous accident?
Not sure which sub threat to post because this repair pertains to the door, frame, skins... ha! Owned this trailer 2 years but this accident happened who knows how many years ago in its life. Obviously was a side swipe of some kind. Check the photos below. Ive already done a little effort to silicone up huge cracks and did a little patch on the underbelly where the old panel was just gone.
The easiest issues I can see if the exterior aluminum got dented but no puncture. I can live with those scratches and try to smooth it out. Shouldn't be a big issue. The lower belt trim was very bent and even cracked. Thats easy to get new trim parts. I do not believe any outriggers were damaged but thats also easy to replace. The frame looks fine. Nothing else on the trailer indicated a tweaked frame.
The hard issues I see are the interior rib in this zone was bent and I either have to try and form it back to shape or find a replacement part/fabricate a new one. I also see door itself was bent in a little at the bottom. I probably cannot fix this. Luckily the door closes but it just requires a little extra shove to latch. I cant find new doors around and I am not willing to pay thousands even if I did. Perhaps when I take the skin off I will find a way to straight it our or fab a new part.
The biggest issue I see is the door frame itself got pretty bent up. This is also a part that I can't find anywhere. I can find ones for trailers in the 2000's but not late 70s. As I was saying the door still closes and it will latch with some extra love. I am worried about this when I do the shell off that its going to cause issues making it even harder to latch closed. Im also worried about water intrusion since thats a tough place to seal up well with the damage. When trying to straighten this whole area out its going to be very awkward to get the aluminum to rivet back again behind this door frame. Its just going to be a very difficult spot to deal with and I don't know what to do about it besides try and shove everything back into place and hope nothing gets worse.
Anyone have ideas as to how I can go about repairing this section of my trailer? Does this raise any huge red flags as to a much bigger problem that will need a serious remedy?
ID:	416376   Click image for larger version
ID:	416378   Click image for larger version
bhel is offline   Reply With Quote
Old 05-22-2022, 07:11 AM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Originally Posted by bhel View Post
.... I am worried about this when I do the shell off that its going to cause issues making it even harder to latch closed. Im also worried about water intrusion since thats a tough place to seal up well with the damage. When trying to straighten this whole area out its going to be very awkward to get the aluminum to rivet back again behind this door frame. Its just going to be a very difficult spot to deal with and I don't know what to do about it besides try and shove everything back into place and hope nothing gets worse.
Not a candidate for a shell off in my book. You will end up having to replace some ribs, the entire side panel and the door. The structural damage usually is worth than it appears. Enjoy it as is and save the $$ for something that is worth to do a full resto to. Just one mans humble opinion.
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 05-22-2022, 09:12 PM   #3
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
We don’t let silicone near an Airstream - looks like a fairly simple panel replacement to me - maybe reskin the door - hard to tell from pictures
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is online now   Reply With Quote
Old 05-23-2022, 12:19 AM   #4
1978 31' Sovereign
What about where the door frame is bent?
Old 05-23-2022, 01:08 AM   #5
1978 31' Sovereign
Well thats a bummer to hear!
I myself feel very good the structural damage is limited to the door frame, C channel and one rib.
Ribs and C channel are easy. But that door frame can give me a lot of grief!
Old 05-23-2022, 06:08 AM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Disassemble down to the individual parts and it should be pretty easy to straighten them up. The alloys that the frames are made out of is pretty soft and malleable and easy to form or reform. I had to deal with a few places on my Globetrotter that were pretty bent up.
Sent from my Lenovo YT3-X90F using Airstream Forums mobile app
Advice needed-accident damage repair Piggy Bank Exterior Restoration Forum 14 05-23-2017 08:31 AM
Zip Dee Awning Repair - Golf Cart Accident jbbaldwin Awnings 0 08-15-2011 01:16 PM
Scrape crunch rip, ouch, parking accident, repair suggestions? jacarape General Repair Forum 12 12-16-2008 09:04 AM
Freak accident w/pics and frame repair question koltys Repairing/Replacing Floor &/or Frame 23 09-27-2007 04:55 AM
New Member - Previous Owner zekethebear Member Introductions 3 11-20-2006 03:35 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
