Old 03-16-2020, 10:13 AM   #1
2018 16' Sport
Tacoma , Washington
How to remove staining below hot water tank hatch
I have lines of staining from hard water (I'm guessing) running down from the hot water hatch cover.
How do remove this discoloration?
The stain lines are smooth to the touch. Not rough or gritty or raised.
I have tried Walbernize and Meguiars wax. Neither did anything to stain. I hesitate to use anything abrasive.
What do you recommend?
Runamuk13 is offline   Reply With Quote
Old 03-16-2020, 10:32 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard...👍
It looks to be the same we get during Winter storage, staining from the white roof coating, try wiping with WD40 and then wax or seal.
More important remove & treat the filiform
More info here.
Stream Happy...
ID:	363379   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."Molly Ivins
“Growing Old…being able to think about the things you can no longer remember.” RLC
"Never tow faster than your Guardian Angel can Fly"
Tahawus....🌥
Old 03-16-2020, 11:22 AM   #3
2018 25' International
Slidell , Louisiana
If WD-40 or Corrosion-X does not remove it, try some white vinegar with a bit of salt, then rinse with water. If that doesn't do anything, polishing compound is safe to use sparingly and won't remove the clear coat especially if you don't rub too hard or for too long.
Brian
BayouBiker is online now   Reply With Quote
Old 03-17-2020, 02:30 PM   #4
2018 16' Sport
Tacoma , Washington
So THAT'S filiform?!?!
I had read about. Now I've experienced it!
OK ..... let the struggle to contain it begin.
Old 03-17-2020, 03:25 PM   #5
Yep..that's it.🥴
Here is a more testicle explanation.🤓
Tahawus....🌥
Old 03-17-2020, 05:19 PM   #6
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Try Lime Away. Hard water is only lime build up. This is not filaform corrosion. The red line points to filaform corrosion.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Staining the wood? Hudsoncamp Eddie Bauer - All Models 7 06-06-2016 05:06 PM
Would like to remove the GE water filter below the kitchen sink flyingfishy Fresh Water Systems 6 12-06-2015 05:57 PM
Staining on white fabric wall covering on 2005 bambi's Kans Upholstery, Blinds, Walls & Interior Finishes 7 08-10-2013 08:16 AM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
H2o leak from below (hot H2O tank ?) bigwoody Water Heaters, Filters & Pumps 3 09-27-2003 06:57 PM
