I had a similar problem with my Safari 25. I used Gorilla Glue and a brad nailer to hold it until the glue set. The tiny brad holes were largely invisible, but we filled them with a furniture touch-up crayon anyway. My wall was bordered with real oak. If yours is just vinyl covered trim, the vinyl may pull away from the base unless you use some kind or mechanical attachment.
Al
