Putting back in the window frame on my 69 ambassador.
Buck riveting.
I cannot get the rivet gun flat at the top of the frame due to the lip of the window "hinge"
What do i need to do?
I could use olympics but would have to hand shave since the shave tool will not fit either.
With a Dremel and a little time you can shave the heads of Olympics to closely match bucked rivets. Might practice on a couple before you try it on the trailer. I did several dozen when I redid my 68 because I could not justify the cost of a rivet shaver for just a few rivets.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
1971 21' Globetrotter
Arvada
As said above, grind a notch in the rivet set. I have rivet sets with all kinds of modifications done to them, it will not effect the performance of the set.
Yes grind riveter ...also owning a 68 you will find owing a rivet shaver is worth the cost over time .... there will be other rivets down the road ...LOL
