Old 02-15-2020, 05:54 AM   #61
2017 20' Flying Cloud
Williamson County , Texas
Originally Posted by Ruscal View Post
If there was no hatch opening cut into the shell the shell would have more rigidity to fight the buckling, but it is a lot to ask of aluminum sheet metal to be required to resist the compressive forces exerted during frame flex. The concentrated loads applied at the tongue/shell juncture are I would guess, pretty high. Possible solution could be to create a gap between the shell and tongue members so the load would be transferred elsewhere. The trim strip could also be clearanced. The gap would allow the frame/tongue member to flex as it is designed to, and the shell would not be deformed. How much gap would you need? Maybe start at a half inch and see what happens when towing over undulating terrain. You could put modeling clay under the gap and observe how the clay deforms. The frame is basically a bow, and the body is rigid. Stress is high at the edge of where flex joins rigid. The hatch having to be there does remove a lot a lot of shear strength of the aluminum body which made the problem show up. Giving Airstream feedback of this would help with a future design solution.
Russ
I agree. I would go in the direction of isolating that area from the frame movement, rather than attempting to reinforce the body to carry the load which may not even be possible.
SYC2Vette is offline   Reply With Quote
Old 02-15-2020, 06:24 AM   #62
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Originally Posted by 66Overlander View Post
I still believe that a front hold down plate is better than a front hatch from a structural integrity standpoint and that very heavy, 1000 lb to 1400 lb, weight bars are not needed in most cases, especially if towing with a 3/4 or 1 ton truck. We tow our 2016 Classic 30 with a 3/4 ton pickup and 550/600 lb trunnion bars even though the tongue weight is well more than 700 lbs. No issues in over 20,000 towing miles.
Everyone has to decide what they are comfortable with. I am just trying to provide a little historical perspective to the discussion.
Very sound comments based on real life towing experience. Thank you for spelling it out!
Dealers equip these trailers with overkill Bars just to cover their rears, disregarding the constuction/dynamics of an Airstream trailer in combination with heavy duty tow vehicles.
AIR #13
PeterH-350LE is offline   Reply With Quote
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 10:18 PM
Univolt common problem 71tradewind 1970-79 Tradewind 21 06-08-2011 11:36 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
Most common problems with 1960s trailers? rluhr 1966-68 Caravel 10 08-21-2003 07:31 AM
