01-26-2021, 12:03 PM
2003 30' Classic
DOVER
, OH
Hot water tank switch
Hello, we purchased our first Airstream. It's a 2003 Classic 30. We love it, and everything about it. I do have a question. There are two hot water tank switches in the bathroom. Which do I use and when? Thanks in advance for any help!
01-26-2021, 12:07 PM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
One is for shore power input and the other is for your propane. Not sure how your trailer was set up, but my guess would be the right is shore power and the left is propane. Propane is quicker, but if hooked to power your using propane when you don't have to.
Bud
2020 28' Twin Flying Cloud-(Our 5th Airstream)
USAF Master Training Instructor (TI) - 68-72
01-26-2021, 12:08 PM
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
IF it's like my 2007 one is for heating with propane has flame symbol and the other is for shore power sparky looking symbol.
Bud got me by a minute!
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
01-26-2021, 12:11 PM
2003 30' Classic
DOVER
, OH
Thanks, I thought that was the case. As usual it's operator error, haha
01-26-2021, 12:13 PM
2003 30' Classic
DOVER
, OH
I'm also scratching my head with the Fantastic fan. We have had numerous campers over the years but this fan setup seems different. Should I have both fans running at the same time, front and rear?
01-26-2021, 01:29 PM
Tampa
As pointed out, the two WH switches are for electric and gas.
On mine there is a red light between them, however it does not light unless there's a problem. I also learned that you can run both electric and gas together and heat the water faster.
That's up to you. If it were me, I'd have one blow in and the other blow out. Seems like it would move a lot of air. Mine won't reverse, though, my old one did.
01-27-2021, 10:59 AM
2017 25' Flying Cloud
Queen Creek
Hot Water Switches
When you identify the electric switch, you can put a lighted on in its place. I put a lighted one on both so it either is on, I will know at a glance. You will have to run a ground to the switches, but it is fairly easy.
01-27-2021, 11:05 AM
1996 25' Excella
Tillsonburg
, Ontario
Use the fans independently as needed. If part of the trailer is in shade, use that fan to blow in. One does not have to run with the other.
JCW
