Old 08-03-2020, 07:56 PM   #1
2012 30' Classic
Babylon , NY
Hot water not running on electric
Runs on gas fine, but will not run on electric. Any ideas why?
kebrita is offline   Reply With Quote
Old 08-04-2020, 03:39 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Holy cow, that is an open ended question. First, I would suggest that if you need to ask the question you should probably take the trailer to a service facility that can do some troubleshooting and repairs, or a mobile service.
The quick check is to check the AC breaker for the water heater. If it is not tripped you could still have a wiring problem to the heating element. It could be a burned out heating element. You could also have a control board problem. That board is located in the compartment that you access from outside, but there is nothing you can do there except replace the board. There is also a relay component in the AC circuit wiring.
In short, it could be a number of things.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-04-2020, 06:19 AM   #3
brokeboater's Avatar
2013 25' Flying Cloud
Crystal River , Florida
Is it a gas only hot water heater? Mines a gas only and I've never been able to get it to work on 110v no matter what I do.
“While you live, shine / Have no grief at all / Life exists only for a short while / And time demands its toll.”
brokeboater is offline   Reply With Quote
Old 08-04-2020, 07:38 AM   #4
Kensington , Maryland
Kebrita,
After you have exhausted the usual suspects you may end up buying this:
https://www.amazon.com/Dinosaur-Elec.../dp/B0130Y8I1K
The install is duck soup.
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 08-04-2020, 08:29 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
If it has been working fine and it is not now my guess would be a bad heating element or the breaker, or.......
I run my water heater on gas all the time even though it has the electric element. So it would not bother me much.
Old 08-04-2020, 08:34 AM   #6
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Are you able to use a meter and follow diagnostic troubleshooting?
Can you provide the model number of the water heater? That allows folks to research wiring diagrams etc.
Checked circuit breaker for water heater?
Gary
GCinSC2 is offline   Reply With Quote
Old 08-05-2020, 08:17 PM   #7
2012 30' Classic
Babylon , NY
hot water heater
Thank you all for the feedback. I did check the breaker and have eliminated that. I have owned the unit for a couple of years and the hot water heater has always run fine on gas but the electric has been spotty at best. We are heading out for our first long trip out west and it would be nice to have both the electric and gas operating. Thank you all, i will follow up with your suggestions starting with the model #.
Old 08-05-2020, 08:25 PM   #8
Spartanguy's Avatar
2021 19' Bambi
San Francisco , California
Maybe it’s a 2021 model....burn
Spartanguy is offline   Reply With Quote
Old 08-05-2020, 11:03 PM   #9
jaybauman's Avatar
2021 33FB Classic
2019 30' Flying Cloud
Katy , Texas
I recently had this same problem and fixed it by replacing the electrical heating element.
Diagnosis:
(1) Heats on gas, but not on electric, so it's not a plumbing problem.
(2) Turn on electric hot water and measure voltage across heating element. I got something close to 120Vac, so I know all the electronics are working correctly.
(3) Replaced heating element. I think I spent about $6 at Home Depot...but the tool to remove/replace the element cost me $10!
(4) Everything now works as designed.
Potential Red Herring: I measured continuity across the heating element, and it appeared to be in good shape. I am guessing I had a bad/damaged heating element that was intact when cold and would lose continuity when heated up. So don't rely on resistance measurements to diagnose electrical heating element troubles.
2021 Classic 33
2020 GMC 3500HD Duramax AT4
ProPride 3P
jaybauman is offline   Reply With Quote
Old 08-06-2020, 06:36 AM   #10
2012 30' Classic
Babylon , NY
hot water heater
jay, Thank you for the detailed process, I will definitely follow your process. I will let you know how i make out.
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot Water Not Hot wepply Sprinter and B-van Forum 12 10-19-2015 08:01 PM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 12:58 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
