Old 01-13-2017, 01:28 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Home on-demand WH
Not directly an AS specific question... thanks in advance for whom ever can assist.
I have a "condensing" on-demand, propane Water Heater. The appliance provides adequate warm water (125 degrees). However, when using or pausing, the doggone thing will rumble and rattle... it shakes walls.
I have taken hopeful diagnostics to no avail..
Does anyone here have time, wisdom and inclination on a solution?
Thanks !!
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-13-2017, 03:09 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Home on-demand WH
Instant tank need to be flushed out to remove lime deposits. There's a special valve that needs to be installed to enable flushing. They use a citrus acid to flush with. It's not harmful to skin and won't contaminate the water supply.
The heat exchanger will fail prematurely if you don't flush it out.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
Bigventure is offline   Reply With Quote
Old 01-13-2017, 03:35 PM   #3
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I agree with Bigventure, you probably have a build-up of mineral deposits. The 6 gallon Attwood in our Airstream started crackling and popping a year ago, when we were camped for an extended period on a limestone mountain, using local well water. It did not get to where it was shaking the walls, but it was noticable.
We flushed the WH with regular water, then introduced a water/vinegar solution through the water pump (as if we were winterizing). We ran the water heater through a heating cycle, let it sit for a few hours, then drained and rinsed again. We got quite a bit of calcite crystals out. The noises stopped.
Then we bought a water softener.
SSquared is offline   Reply With Quote
Old 01-13-2017, 06:08 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thank you!!! Will do as you recommend! I don't think the WH is made anymore.. so may have a short service life if it can't be resolved.
Channing
WBCCI# 30676
Old 01-13-2017, 06:55 PM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Hello all,
New guy here and have been lurking to learn all I can about Airstreams prior to purchasing, much more to it than I first though!
Anyway I am a licensed plumber and have dealt with your issue, I think you should try(if you can access) the combustion blower and clean the impeller and any ducting associated with the air flow for combustion. My own Takagi did this and I was able to cheat the system by changing fan speed with a dip switch, this is a band aid fix but it worked.
Yesterday I repaired a customer HTP high efficiency W/H that uses similar technology by cleaning the swirl plate ahead of the combustion blower and vacuuming the airway and the loud distructive sounding pulsating noise is GONE.
Good Luck!
AlinCal is offline   Reply With Quote
Old 01-17-2017, 07:47 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Great ideas! Thanks!
Channing
WBCCI# 30676
Old 02-02-2017, 01:05 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Problem resolved! Replaced with Navien.
Channing
WBCCI# 30676
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
Rising demand 4 tow Vehicles ArtStream Tow Vehicles 2 12-02-2006 08:23 AM
Converting pressurized water system to demand.. Is tank vent needed 63air Water Heaters, Filters & Pumps 1 07-05-2005 10:11 PM
Time for a new demand H2O pump thenewkid64 Water Heaters, Filters & Pumps 14 09-26-2003 02:34 PM
