Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-10-2020, 11:58 AM   #1
dznf0g's Avatar
Oswego , Illinois
Help with Chrome Plating removal
Looking for some help and suggestions. Years ago, I purchased my Rocktamers with the chrome plated aluminum yoke and arms. Of course, water got under the chrome and the aluminum has oxidized and lifted most of the chrome plating off. I decided to clean up, prep and paint. Problem is, about 90% of the plating comes off and 10% is still well adhered to the aluminum substrate. How can I get the remaining chrome off? I've poked, scraped and wire wheeled all I can get mechanically. Is there a solution which will etch and lift the chrome? Can I paint over some of the chrome? If so, prep suggestions?
Someone is bound to say, "Just replace the yoke." Well, a few years ago, when I had more money than time, I would have. I now have more time than money.......you get it.
-Rich-
Old 04-10-2020, 12:37 PM   #2
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Email these guys and see if any of their Blue Bear products will work on it. It's a fairly new process made from soy. Very safe to use.
Franmar.com
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 04-10-2020, 12:41 PM   #3
"Cloudsplitter"
Heat and Whack. and wire brush.
Old 04-10-2020, 12:54 PM   #4
dznf0g's Avatar
Oswego , Illinois
Thanks, I'll look into it
Franmar.com
-Rich-
Old 04-10-2020, 12:55 PM   #5
dznf0g's Avatar
Oswego , Illinois
[emoji631]
Tell me more. Wire brush, yes...but heat? Technique?
-Rich-
Old 04-10-2020, 02:21 PM   #6
"Cloudsplitter"
On the rear bumper of our 73 Blazer a lot of the chrome had rusted and flaked off, what didn't come off by scraping was loosened up by heating,(blue chrome) & hammer tapping as it cooled. Power wire brush, heavy sanding and 2 coats of brush on enamel and it was ready for another 2 yrs.
Old 04-11-2020, 11:16 AM   #7
Eric 26 Argo's Avatar
Airstream - Other
Knoxville , TN
You can take it to a chrome plating shop and they can dip the item to remove the plating. Usually it will be chrome on nickle. I have had bumpers done so I could paint them.
Eric 26 Argo is offline   Reply With Quote
Old 04-11-2020, 11:59 AM   #8
Boxite's Avatar
2008 22' Safari
Have you considered “reversing” the chrome-plating process?
Chrome is plated onto a substrate using electro-plating processes. The chrome can be just as effectively removed by reversing the current.
You tube has several videos on this subject.
Wikipedia explains the basic process: https://en.wikipedia.org/wiki/Electroplating
Old 04-11-2020, 01:32 PM   #9
1972 23' Safari
troup , Texas
I tried muriatic acid on a hubcap recently and it really did a job. may find at a pool supply(swimming) dont breathe the fumes and wear protection
72sahara is offline   Reply With Quote
Old 04-11-2020, 03:01 PM   #10
1976 31' Sovereign
Oswego , Illinois
Thumbs down
Muriatic acid will eat aluminum.
Old 04-11-2020, 06:40 PM   #11
dznf0g's Avatar
Oswego , Illinois
I read that online.
-Rich-
Old 04-12-2020, 07:14 AM   #12
1976 31' Sovereign
Oswego , Illinois
Wink
It is fact when we were racing 2 cycle motorcycles. When pistons seized in cylinders, used muriatic acid to clean aluminum out and some times deposits were heavy, did not damage steel liners in cylinders, after cleaning, good to go no further cleaning needed
Old 04-22-2020, 12:07 PM   #13
2018 30' Classic
Jacksonville , Florida
I was going to say just leave it near the brick wall when my masons are cleaning brick. Chrome comes off doors rust and the brick looks ok. Acid won't like the aluminum very well. Never heard of chrome over aluminum.
Overstreet is offline   Reply With Quote
Chrome wheel covers for Classic 345 AccessMaster Airstream Motorhome Forums 17 10-10-2019 11:13 PM
Plating of fixtures RankAm Ribs, Skins & Rivets 0 07-29-2009 10:30 PM
To chrome or not to chrome Kiah Upholstery, Blinds, Walls & Interior Finishes 9 11-22-2007 02:26 PM
Chrome Canister "U-FIL" Water Filter jaco Water Heaters, Filters & Pumps 1 05-06-2004 01:53 PM
