Old 03-05-2021, 01:44 PM   #1
2021 30' Flying Cloud
Oakland , California
Help, can’t find jack fuse
I have a 2020 Flying Cloud 25FB with a Barker Mfg VIP 3500 jack. A family member reversed direction on the jack too quickly and I believe the jack fuse blew. I have a 30A, 250V slo-blo fuse to replace it, but I can’t find where it is.
The cable back from the jack to the spare tire all seems more slender than a fuse. Right near the tire is a bulged area that *might* be fuse-width but is encased in heat-shrink plastic I’m loath to cut open. I don’t see a fuse holder anywhere along the line.
Any tips? Thanks so much.
precipice is offline   Reply With Quote
Old 03-05-2021, 02:02 PM   #2
heslinhotel's Avatar
1989 29' Excella
1999 25' Safari
Youngsville , North Carolina
Precipice,
The bulge area is probably the fuse. Tongue jacks are wired directly to battery with the fuse inline between jack and battery. If you have a 12v test light you can confirm power. First check if you have a light on the jack, see if it works, if it does there is power to jack and no need to unwrap fuse to test.
Steve
heslinhotel is offline   Reply With Quote
Old 03-05-2021, 02:46 PM   #3
Originally Posted by heslinhotel View Post
Precipice,
Steve
Awesome, thank you. Light on the jack is also not working.
Old 03-05-2021, 02:58 PM   #4
2019 30' International
Pennsylvania , Pennsylvania
I had a '16 flying cloud, and now a '19 International Serenity.
Jack fuse on both were/are inside the battery box.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 03-05-2021, 03:00 PM   #5
Also, on my units, there is/was no unwrapping to get to the fuse. It's a typical twist/push lock.
Old 03-05-2021, 03:53 PM   #6
dznf0g's Avatar
Oswego , Illinois
My 2007 Barker jack has no fuse. The jack is wired directly to a 30 amp self resetting circuit breaker at the positive buss.
-Rich-
Old 03-05-2021, 11:10 PM   #7
Well, I figured it out. We had a solar/lithium install done and they took out the batteries from the battery box. The jack fuse was under the bed with the lithium batteries.
So, advice in general: look for the jack fuse next to your batteries, wherever they are!
Thanks for all the help.
Old 03-06-2021, 09:38 AM   #8
1977 31' Sovereign
Bartlett , TN
The bulge you found is probably where they spliced the wire. Just keep in mind that the jack wire is small gauge, probably no larger than 12 ga. and has no protection from the fuse back to the battery or battery buss. If you relocate jack fuse or breaker to feed directly from the buss, you eliminate any small unprotected wire that could start a fire if shorted.
jsaucier is offline   Reply With Quote
Old 03-06-2021, 10:08 AM   #9
"Cloudsplitter"
10/4... same on 'Cloudsplitter'
I can’t find the fuse / circuit breakers eliyahu Electrical - Systems, Generators, Batteries & Solar 10 12-12-2017 04:14 PM
Help!! I can't find the fuse panel in my 1993 Land Yacht V495 Falkenbergs Land Yacht/Legacy Motorhomes 4 05-23-2012 07:44 AM
can't find 12 volt fuse box on 1988 32ft. excella charleshanse Member Introductions 1 05-08-2012 08:14 AM
Can't find the 12V fuse bus... lilduckidan General Repair Forum 5 02-13-2012 12:35 AM
Can't find the 12 volt fuse panel in my 1976 31 foot Sovereign clboyd Batteries, Univolts, Converters & Inverters 20 01-30-2009 06:02 PM
