Old 04-11-2021, 11:19 AM   #1
1997 Airstream Landyacht
1997 33' Land Yacht
Holladay , Utah
Help - 1997 Landyacht sewer hose adapter?
Hello all.
So I purchased the Camco RhinoFlex Heavy Duty RV Sewer Hose Kit, but the bayonet fitting (with four prongs) does not fit on the 1997 Landyacht sewer pipe. The landyacht sewer pipe seems to be about a 1/4" to 1/2" bigger than what the Camco is expecting.
I have scoured the manual for info on the correct sewer pipe fitting but have had zero luck.
Anyone out there know what the correct sewer hose kit is for a 1997 Landyacht?
Carinabrewer is offline   Reply With Quote
Old 04-11-2021, 11:42 AM   #2
1986 31' Sovereign
Miami , Florida
You need a Valterra to Thetford adapter.
https://www.etrailer.com/RV-Sewer-Ho...nt=30%20-%2060
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 04-19-2021, 09:05 AM   #3
1997 33' Land Yacht
Holladay , Utah
Thank you!
Thank you @n2916s !
I found the adapter , I put it directly into the rv sewer pipe, and the “regular” hose fits much better.
Thank you for the tip! No way I would have figured this out on my own...
I have only used it once- but there is waste water that leaks between the adapter and hose. Just looks like poor design as the hose/adapter don’t join together tightly.
Old 04-19-2021, 10:22 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Maybe try another adaptor or hose. Is the gasket in place? That is not a joint that usually leaks. It is certainly not a poor design problem. What you can do that might make things better is to install the adaptor on the dump outlet with silicone seal. And you can get neat little plastic levers to tighten and loosen the Rhino fittings. When you get it right it will not leak.
If you are bold and if there is enough pipe showing you can cut off the Telford fitting and permanently install a Valterra fitting. That is what I did on my trailer.
Bill M. is online now   Reply With Quote
Sewer hose adapter astrocaver Waste Systems, Tanks & Totes 7 10-30-2018 08:03 AM
OEM Sewer Hose Adapter Needed xengineer Plumbing - Systems & Fixtures 1 06-30-2018 03:23 PM
Sewer Hose Adapter Size Problem crabbey1 Waste Systems, Tanks & Totes 9 05-04-2015 11:53 AM
sewer hose adapter ericwarren Waste Systems, Tanks & Totes 18 10-16-2008 05:52 PM
Sewer Hose Adapter kjj422 Waste Systems, Tanks & Totes 12 07-23-2008 11:28 AM
