Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-02-2021, 09:24 PM   #1
WT1J's Avatar
2018 27' Flying Cloud
2020 25' Flying Cloud
2021 30' Flying Cloud
Redmond , Washington
Grey and Black switched in a 2021 FC30FBO
Took delivery of a 2021 Flying Cloud 30FBO a few months ago. I have it on its first shakedown run. Dumped for the first time, and the black and grey tanks are switched.
Main equals Grey.
Auxiliary equals Black.
I only needed to dump the grey, so I pulled Aux and got black. Couldn't believe my eyes. Woohoo!! Thankfully there wasn't much in there, and the grey was full, so I could just wash it all away. Pure luck that the one time I'm only dumping grey, they switched it on a new airstream.
Anyone ever seen this? I'm a bit baffled by it. I'll compare it to my 2018FCFB that is parked alongside it, but I'm guessing they reversed the riveted labels on the levers?
Regards,
Mark.
2018 Flying Cloud 27FB
2020 Flying Cloud 25
WT1J is offline   Reply With Quote
Old 12-03-2021, 06:53 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
On our classic the main is on the left, closest to back tire. The aux - grey is in the right. It is possible that the plates need to be switched or that airstream did change it. I’d check with airstream or dealer for clarification on if it changed or if your tanks got swapped or if it’s just as simple as swapping the plates
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 12-03-2021, 07:07 AM   #3
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
That was a big problem about 5 years ago.......I believe they were smoking to much weed on the assembly line, or it was a disgruntled employee. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 12-03-2021, 04:07 PM   #4
WT1J's Avatar
I think they may be producing too fast. There were a few other minor oversights.
Old 12-03-2021, 11:22 PM   #5
2016 30' International
redondo beach , California
For bathroom duties use the kitchen sink. For cooking and washing dishes use the bathroom.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 12-04-2021, 03:28 AM   #6
2021 27' Globetrotter
Daytona Beach , Florida
nitzo is offline   Reply With Quote
Old 12-04-2021, 07:16 AM   #7
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Curious that long after the industry switched to using the terms "black" and "gray" Airstream still uses "main" and "auxiliary" to label the tanks.
Can't say how many times I've had to stop and think which is which before pulling the handles. Looks like even the folks building the trailers can't keep it straight which is which, at least when it's time to put the labels on.
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 12-04-2021, 10:26 AM   #8
Ottawa , ON
I made a couple of labels, "Grey" and "Black", and stuck them on the bracket next to the handles. Way more informative than "Main" and "Aux"!
Stonecraft is offline   Reply With Quote
Old 12-04-2021, 10:51 AM   #9
2015 25' FB Flying Cloud
Huntley , Illinois
Do the tanks diff in size? Could make a difference in volume for grey if empties into a smaller tank
cegardner is offline   Reply With Quote
Old 12-04-2021, 12:23 PM   #10
1964 30' Sovereign
Ione , CA
At least the plumbing was attached to your tanks upstream and downstream. But that's just poor workmanship...wow.
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
Trowbridge is offline   Reply With Quote
Old 12-04-2021, 12:40 PM   #11
greenflag's Avatar
Quartz Hill , California
When I bought my 2016 the tanks were switched from my 2007.
I put a gray handle on the gray tank drain.
greenflag is offline   Reply With Quote
Old 12-04-2021, 04:26 PM   #12
Rltports's Avatar
2015 25' Flying Cloud
Bettendorf , Iowa
That’s interesting…. The handles on mine are black and gray for the correct valve. No labels. Seems strange they would change something that is simple and makes sense. BTW.. my FC is a 2015.
Rltports is offline   Reply With Quote
Old 12-04-2021, 04:28 PM   #13
2015 27' Flying Cloud
Gainesville , Georgia
You could check by running 20-25 gallons of water in the kitchen sink and looking at the gauges above the sink. Grey gauge should show more than half full. doubtful they reversed the tanks - likely just the labels. You definitely want the gauges to correspond with the proper tank.
DIDJA is offline   Reply With Quote
Old 12-04-2021, 06:35 PM   #14
On Comet
2017 25' Flying Cloud
Santee , California
Valve tag positions switched
I had a similar issue with my new 2017 Flying Cloud. The gray water drain handle was labeled as the black water tank and visa versa.
I contacted the factory and they sent me out replacement labels immediately and at no charge.
Silver Comet is offline   Reply With Quote
Old 12-05-2021, 04:51 AM   #15
Colossus's Avatar
Peachtree City , Alabama
I second the question “does the tanks differ in size”? The answer to this question would definitely alter how I could use the trailer. Better to find out now before you’re out on the road.
Colossus is offline   Reply With Quote
Old 12-05-2021, 06:42 AM   #16
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Just for clarification and in response to some of the previous posts, what you are suggesting is the valves are labeled backwards, not that the tanks are actually connected wrong, correct? But you could verify this as described above.
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 12-06-2021, 02:06 PM   #17
On Comet
Santee , California
Hi Fran&Frank; in my case the valves were simply mis-labeled. (I had the trailer for a year before I noticed...)
Old 12-06-2021, 02:29 PM   #18
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
The black water pipe (3.0") and gate valve is larger than the grey water pipe (1.5") and valve, at least it is on our 2015 23FB.
Steamy1 is offline   Reply With Quote
Old 12-08-2021, 10:58 AM   #19
1988 32' Excella
Robbinsville , New Jersey
In general black tank is smaller, how much varies with trailer size. From the ones I checked the newer 25' and larger trailers are close to the same (within 5 gallons), on the 23' the gray is close to double the size of the black.
Old 12-08-2021, 08:42 PM   #20
Colossus's Avatar
5 gallons in size difference isn’t the end of the world. If I had the choice, I’d prefer the grey to be larger as it was designed. I remember when I had my 23’ the black and grey tanks were significantly different in size as you mentioned.
Just switched to two 6V batteries: amazing results Aolani Batteries, Univolts, Converters & Inverters 75 03-04-2019 11:38 AM
Sewage and WasteWater Labels Switched? Adventure.AS Waste Systems, Tanks & Totes 39 04-26-2017 11:37 PM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 07:47 PM
Switched to a motorhome! 48-remi Member Introductions 2 02-01-2006 07:46 PM
Heat pump switched on in AC mode Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-22-2005 09:09 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
