Old 12-19-2016, 09:27 PM   #1
1996 35' Land Yacht Widebody
council grove , Kansas
Getting ready to roll
Hello,
I bought a 96 Landyacht that I'm trying to get ready for travel
and I have some questions.
Firstly, the solar panel display by the microwave doesn't come on.
Is there a fuse for this. I see an inverter?in the compartment with the
shore power cords that I don't believe is working- is there a fuse for the
receptacle that it's plugged into. Thanks Merrill
merrillv is offline   Reply With Quote
Old 12-22-2016, 11:32 AM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Originally Posted by merrillv View Post
Hello,
Having had a '94 LY diesel pusher, there was no factory install of solar - that was added by the PO. The "panel" you are most likely referring to is the solar controller. What is the brand name and model of the controller? Changing the controller is not a huge job or expense, and it is likely that you may be better off doing so, particularly since the newer ones are multi-stage MPPT types.
As for the inverter, there are a number of different brands and wiring options.
None of these questions are OEM, they are addons by the PO. You will need to have someone knowledgeable in electricity (such as an RV tech) check it all out for you.
Good luck and enjoy your LY.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Need some tips on getting my first Airstream ready to roll suzieleigh On The Road... 40 02-20-2014 12:05 AM
Getting our '75 Sovereign ready to roll! heeeeelp teamkeira 1974 - 1979 Sovereign 63 02-20-2011 11:28 PM
Getting ready to get ready to think about an AS pinkflamingoes Our Community 22 10-04-2004 06:36 PM
Ready to Roll a difficult read... Safari Tim Our Community 1 01-20-2004 12:09 PM
