07-24-2021, 01:23 PM
2014 25' FB Eddie Bauer
Glen Arbor
, Michigan
Gas shock for cabinet above Fridge?
Our 2014 25 Eddie Bauer doesn't have any support mechanism for the lift up cabinet above the fridge. Has anyone figured out what the right shock size and strength would be for that and where to place it? I am assuming that the newer units have something because it is a pain.
07-24-2021, 02:29 PM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
I use piano bench hinges on both that cabinet and the bathroom mirror in our 2014 international 25ft FB.
Been working great for 7 years now no problem.
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
I used these on our EB.
Apexstone 100n 10”. Available on eBay. Also installed 2 on the overhead cabinet in bathroom. Attachment 1
Also works well with Flying Cloud 25 and 27.
07-24-2021, 02:33 PM
Senior Member
Sparks
, Nevada
07-24-2021, 08:00 PM
Glen Arbor
, Michigan
Apexstone 100n 10”. Available on eBay. Also installed 2 on the overhead cabinet in bathroom. Attachment 400274Attachment 1
This is perfect and so helpful. Thanks a ton! I am going to do the exact same thing.
07-25-2021, 10:30 AM
2008 27' International FB
Petaluma
In our 27FB we added these gas springs to the above fridge cabinet door and to the bath mirror cabinet door to hold them up while open:
07-25-2021, 04:38 PM
2017 27' Tommy Bahama
Narragansett
, Rhode Island
Above-Refer Cabinet Door Support
I searched for quite a while for this same solution.. I wanted a soft close support that would stay open until I closed it. I found a great product:
Sugatone NSDX-35RK
It works perfectly.
See attached details.
2017 Tommy Bahama 27FB
2016 GMC Yukon XL
“Attitude is a little thing that makes a big difference” - Winston Churchill
07-25-2021, 05:31 PM
2014 25' Flying Cloud
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay
Anyone have a current link to order these hinges? It seems the links provided so far might be old as they say “sorry page not found.”
☘ 369goose
"The world is a book and those who do not travel read only one page.” – St. Augustine
07-25-2021, 09:06 PM
Glen Arbor
, Michigan
Sugatone NSDX-35RK
It works perfectly.
I
That looks like a great solution.
Did one work or did you need two?
07-25-2021, 09:27 PM
Senior Member
Sparks
, Nevada
One on the fridge cabinet, 2 on the bathroom.
07-25-2021, 10:09 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
Comes in Left side, too
https://www.ovisonline.com/Soft-Clos...ght-P1740.aspx
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
07-25-2021, 11:33 PM
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
I know that these aren't quite as fancy as the other solutions shown, but I only needed one for each application as they lock in place.
And don't take up much room inside the cabinet when folded in.
07-26-2021, 05:35 AM
Narragansett
, Rhode Island
Originally Posted by Wanna EB
I
I used one for over the refrigerator. You can order one for the right side or left. I used a right side support because I have a solar control panel inside the cabinet on the right, so that side already has restricted space.
If you search the manufacturer’s web page, you will see a few options on how to mount the support. I had to get a small part separate from the support.
I noted a previous person used their support on the bathroom cabinet also. My Tommy Bahama came with two large supports from the factory. You might want to search the parts catalog for the exact ones they used. Mine are way too large to also be used over the refrigerator.
Here is a link to the manufacturer web page:
www.sugatsune. I note the name in my original post was spellchecked, it should be Sugatsune.
2016 GMC Yukon XL
07-26-2021, 07:36 AM
Petaluma
Sorry, here's a good link (I hope). - Brad
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
07-26-2021, 09:01 PM
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay
Originally Posted by SeeMore
Thank you
☘ 369goose
07-27-2021, 06:30 AM
Narragansett
, Rhode Island
Cabinet Support
Here is the support I described from a reliable website:
https://www.woodcraft.com/products/s...aAh28EALw_wcB#
2016 GMC Yukon XL
