Old 04-09-2018, 08:55 AM   #1
2016 23' Flying Cloud
Brick , New Jersey
Fuse Panel Confusion
I recently purchased a 2016 23FB. In a "senior moment" I removed one of the 30 Amp fuses so I could match it up at an Auto Zone for the same style. Well, when I came back to the fuse box I sort of remembered where it went. The problem is there are three 30A fuse locations on this box and I am questioning which spot it went in. To add insult to injury I began playing three card monte with the slots. I must admit I am a bit confused at this point. I have a attached a picture which is my current configuration (two together to the left). It is not clear on the panel since one is a spare. Can someone help me with this? Thanks Chris
Profcbutler is offline   Reply With Quote
Old 04-09-2018, 06:55 PM   #2
1965 24' Tradewind
Chestertown , Maryland
Iím not seeing a picture. But what is t working with it out? Put it back into a slot until that thing works.
jcslocum is offline   Reply With Quote
Old 04-09-2018, 07:26 PM   #3
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Your owners manual has diagrams in section 8 that show the 12v fuse layout.
Alan
Old 04-09-2018, 07:38 PM   #4
PKI
PKI's Avatar
Walnut Creek , California
Use the two outside positions.
There are converter install threads that you can search and see the fuse locations on the DC board. Good luck. Pat
http://www.airforums.com/forums/f449...es-162905.html try this link
Old 04-09-2018, 08:27 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Just put a fuse in all 3 slots. Problem Solved.
Old 04-28-2018, 08:49 AM   #6
Brick , New Jersey
Thank you for all responses. I just changed out the converter and DC board with a four stage converter (as recommended in the AS battery forum). The new DC board only has two spots for a 30 amp fuse. Problem solved:
As a side note I love this charger. No more burning batteries and with the pendant I can see the status of the charging. A really great upgrade, and easy to do. Only took me about two hours and $250
2016 23fb fuse panel, 2016 fuse panel, 30 amp fuse location
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
12v fuse panel location? coldduc All Argosy Trailers 5 05-26-2004 06:15 PM
What size fuse for 12-volt panel? paddy79 Electrical - Systems, Generators, Batteries & Solar 4 05-23-2004 08:39 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
