I can't get my furnace to start on my recently acquired 2004 Landyacht. I have propane (stove works) and my batteries are charged. I'm currently connected to shore power. I turned the switch off and back on at the burner. I also noticed no blinks from LED on furnace circuit board when trying to start furnace. Is there a way to determine if my circuit board failed? Any thoughts on this are appreciated.
Looking at your photo, see the switch is in the off position. Could this be it?
I wish that was the answer, but it's not. I had turned the switch off and back on several times to try resetting it. But that didn't fix anything. I must have taken the picture when the switch happened to be in the off position.
I would make sure power (12 volts) is getting to the furnace and that the thermostat is working. Te thermostat should only have 2 wires and is an on and off switch.
Richard Wally Byam Airstream Club 7513
